wont start, need some help please! - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 07-11-2011, 7:14 PM Thread Starter
Reputation Power: 11
Hey guys!
First off, let me start with a little background on what happened to the bike. It was a basket case when I got it, but its a 96 cbr900rr. The bike was overheated or something. I live in Indiana so we have cold winters and there was water in the radiator so that might have messed something up. Either way, there was a nasty section in the cam chain area that blew out in the cylinder head. I found a new head off ebay for a 97' which to my knowledge works with my year. With that I also got a gasket kit and a few other misc. parts I needed. I got it pretty much all the way buttoned up, but I'm starting to do some of the wiring and having issues. For starters, its got no body so no lights or instrument cluster. I only have some lights in the back by the license plate for running lights and brakes. Have lights for blinkers, but not worried about those at the moment, just wanna get it running.
I guess my question is what all exactly needs to be plugged in to get the bike to start? I'm guessing things like the neutral indicator, side stand switch, kill switch, and starter button are needed, but things like the temp sensors and other odds and ends. Do I need the clutch sensor plugged in, and also do I need to have the clutch in to start the bike? I thought as long as the neutral switch/light was on it would start with no clutch or kick stand. Not too sure, and any help is GREATLY appreciated!!! I thought I had basically everything plugged up temp. and tried to start her, but wasn't getting anything. Well, it was turning over with the starter and the lights in the back were working. The sounds it was making sounded familiar coming out the exhaust (like it had decent timing, nothing was clicking to my knowledge or banging against anything). I think I wasn't getting spark, but not sure. I wanna run compression checks also.
With all that, the oil and radiator fluid did mix, making that chocolate milk looking crap and then the bike did sit for a bit taken apart. What can I do to clean the carbs? As I'm thinking that could be an issue also. When I took the fuel tank back off, there was gas in the line after the petcock and before the carbs, but that doesn't mean its flowing well inside them.
Thanks again for any help!
adidrick is offline
post #2 of 10 Old 07-11-2011, 11:44 PM
Re: wont start, need some help please!
Originally Posted by adidrick View Post
Hey guys!
To see if you have spark spray starter fluid into the airbox while cranking the engine over. If it fires then you have spark.
The carbs will need to be completely disassembled and cleaned with carb cleaner and compressed air.
post #3 of 10 Old 07-12-2011, 1:26 AM Thread Starter
What are these grounds for? They are a bunch of green wires.
And also, there is a small wire for the water temp sensor, and neutral switch and a small ground. Anyone recall where that went? It has a rubber grommet over it and is pretty small in diameter, and is the blue connector in the wiring harness.
Thanks for your help guys!
adidrick is offline
post #4 of 10 Old 07-12-2011, 2:20 PM Thread Starter
don't know why, but my picture from above isn't working...
adidrick is offline
post #5 of 10 Old 07-12-2011, 2:21 PM Thread Starter
well, nevermind, none of my pictures are working.....they were last night.....dirty.
adidrick is offline
post #6 of 10 Old 07-12-2011, 4:32 PM Thread Starter
well, i wired up the harness again and found out a few things i wasn't doing right. so fixed those and tried again to fire it using blades technique of using starter fluid, and it wanted to start! so i have spark i believe! now i just have to do something about the carbs. anyone know some average prices of getting carbs cleaned? i'm going to call some local shops but i wanna try and get some ballpark numbers.
thanks!
adidrick is offline
post #7 of 10 Old 07-13-2011, 2:56 AM Thread Starter
it's alive!!!!! finally got it running!
couple questions.
1. my throttle doesn't snap back like it should, what are some causes of that??
2. my clutch is kinda hard to pull in. how much resistance should i be getting? and is it normally ran through the area where the throttle cables go? and then to the clutch puller? nothing is kinked in the clutch line or the throttle cables, what could be causing the clutch to be so hard??
adidrick is offline
post #8 of 10 Old 07-13-2011, 2:59 AM Thread Starter
how do you link a video i uploaded on facebook?
adidrick is offline
post #9 of 10 Old 07-13-2011, 8:33 AM
couple questions.
Check that no hoses or wiring are fouling against the cables or throttle linkages but usually the problem is worn dirty cables. You can also try backing off the adjuster a couple of turns to ensure they're not too tight.
If that doesn't fix it then take the cables off and clean them. I use WD40 or INOX and keep working the cable until it runs out the other end.
A frayed clutch cable often has a dead sort of feel to it. Considering the age of the bike maybe just put a new cable on it.
post #10 of 10 Old 07-15-2011, 1:31 AM Thread Starter
little update....got the throttle cables working GREAT! just played with the adjustment bolts down by the carbs and the grip snaps back to its regular spot nice and quick! took the clutch cable off for now. i'm gonna wire up some turn signals, brake lights, license plate light, and running lights some how. i think i'm gonna unwrap the harness and try and clean it up a bit so i can tuck things a bit better and make it nice and clean.
i'd like to use some type of shrink wrap to wrap the harness in, is anyone aware of any type of wrap that would work? i would imagine you need to get the right wrap over the wires before you put the connectors on. is there any type of wrap out that there that can fit over the connectors but still shrink? if not i'm just going to use electrical tape.
one last thing i wanna do is get a bigger headlight with a working low and high beam setup. any suggestions out there for that, i like the look of the bigger sized buell type single headlight. something about 5-7" range but not really deep.
thanks for looking and any help guys!
adidrick is offline
98 F3 wont start billb600f3 Honda CBR 600 0 07-04-2010 1:16 PM
my 954 wont start ballinbauer Honda FireBlade 3 04-21-2010 2:38 AM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-19-2010 12:58 AM
WONT START! temperedtim929 Honda FireBlade 0 10-07-2008 9:56 AM
954 wont start jump-jet Honda FireBlade 3 10-26-2007 3:20 PM
