929 boiling coolant at 227F? - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 07-19-2011, 11:50 AM Thread Starter
My fan is working but only keeps it at 227-228 at a red light or driving slow. If I turn it off at that temp it is boiling in reservoir? No signs of head gasket problems such as cloudy oil or oily coolent yet. Maybe just needs flush. Run honda coolent, never had a problem before. Thanks for your time.
I just took notice of fan coming on at 225, turned it off & was already boiling in reservoir at 225 deg? Shouldnt my fan kick in at 217? & would it be boiling that much at 224-225? Again, thanks for your time, new to sportbikes.
Ratracer is offline
post #2 of 7 Old 07-19-2011, 1:32 PM
Reputation Power: 9
Re: 929 boiling coolant at 227F?
I would flush it out, shouldnt be boiling till 265 or so.
rubbersdown is offline
post #3 of 7 Old 07-19-2011, 6:04 PM
hfb
Is the coolent circulating ie is the water pump working and is the thermostate opening.
hfb is offline
post #4 of 7 Old 07-19-2011, 6:27 PM Thread Starter
How do I check water pump. I dont think it is circulating. I hop[e to have time after work to check it out. Thanks
Ratracer is offline
post #5 of 7 Old 07-19-2011, 8:35 PM Thread Starter
When I squeeze hose I feel no pressure. Nothing leaking from pump. Nothing circulating. Guess I will order a thermo? Anyone know other test I could do to determine which is faulty? Thanks
Ratracer is offline
post #6 of 7 Old 07-19-2011, 9:47 PM
Quoted: 51 Post(s)
Reputation Power: 98
Before you start replacing parts take off your rad cap, run the bike and see if there is any air in your system by bringing it to boil up, switch it off, replace the cap and see how the system operates. If it is still getting too hot then start going through the system for other issues
oxman1196 is offline
post #7 of 7 Old 07-20-2011, 2:57 PM Thread Starter
Had done that & seen no circulation. Shouldnt be air because was fine since i changed fluid last year. Thanks, will try the thermo.
Ratracer is offline
Oil in coolant? mrtarivera Honda FireBlade 13 04-20-2011 4:10 PM
I may have coolant in my oil? whitarnold Honda FireBlade 0 04-19-2011 6:19 PM
Coolant BurtonF166 Honda FireBlade 5 07-16-2008 12:14 AM
Boiling Battery Caggers Electronics 4 10-25-2007 1:14 AM
Changing Coolant / Flushing Coolant? cbr9two9guy Honda FireBlade 3 07-10-2005 10:13 AM
