929 stator casing issues HELP PLEASE - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 07-21-2011, 3:26 PM Thread Starter
Need help!!
Dropped the bike on the left side and needed to replace casing and stator
When i bolt up the casing it locks up the engine! Turns over ok when the casing is off. I got a used casing and i'm thinking it could be bent and pinching the idler gear for the starter??
I didnt replace the gasket i just used instant gasket crap, could this cause any clearance probs? I removed the stator from the casing altogether and tried it and its still the same,there is a hairline crack inside the cover so must of got a bit of a bang but doesnt look out of shape.
SP1 Lover is offline
post #2 of 6 Old 07-22-2011, 4:41 AM Thread Starter
Re: 929 stator casing issues HELP PLEASE
Tried turning it over with no casing and it isnt turning freely, seems to catch slightly at a certain point. Could the flywheel be bent??
post #3 of 6 Old 07-22-2011, 10:01 AM
Put the cover on and back the screws out one turn each and see if it spins.
I would definately use a gasket.
post #4 of 6 Old 07-22-2011, 12:24 PM Thread Starter
have done that mate, with the cover loose you can see it move a bit. that shouldnt happen i presume?
My thinking is the flywheel/ringgear is a bit bent causing it to get too tight at a certain point with the idler gear....Get a new flywheel and gasket and try again perhaps?
That or the crank is damaged which aint going to be worth doing. I'm in a huge hole with this now i have got a new side fairing,nose cone and tail piece and now this happens
post #5 of 6 Old 07-22-2011, 6:41 PM
You do have the locating dowels installed?
If it's touching something you should be able to see some witness marks.
post #6 of 6 Old 08-02-2011, 4:44 AM Thread Starter
Turned out the flywheel/ring gear was the problem must have been slightly bent causing it to get tight on the idler at a certain point. Its turning over perfect now
Thanks for the help
stator cover&lower casing dacarius Honda FireBlade 1 12-03-2010 8:02 PM
954 Stator Issues fortknox82 Honda FireBlade 5 11-29-2010 12:54 PM
Reg/rec issues? or stator... chakraist Honda FireBlade 7 05-03-2010 7:44 PM
POLL - To all that ever experienced fireblade charging/stator issues MACI4LIFE Honda FireBlade 9 09-02-2009 12:06 PM
Alternator/stator issues !! Black 929 General Discussion 9 06-18-2009 6:59 PM
