954 engine knock - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 07-23-2011, 7:16 AM Thread Starter
Reputation Power: 10
954 engine knock
Help. My 02 954 has developed an intermittent knock from somewhere in the engine. Its not evident when the engine is cold but gets louder as the bike gets hotter. Pulling the clutch in doesnt make any difference. It does go away as soon as you put some load on the engine. So its can be heard at tickover and when you rev the engine it shows up as the engine revs drop. It also seems to come and go and is not regular.
Any ideas?
ahthud is offline
post #2 of 9 Old 07-23-2011, 12:07 PM
Reputation Power: 11
Re: 954 engine knock
I have the same thing. almost sounds like valves. Only appears when the engine is up to temp
Midwestrider is offline
post #3 of 9 Old 07-23-2011, 3:27 PM Thread Starter
Mines definitely not valves (valve gaps checked less than a month ago). Its also to much of a knock rather than a rattle/tick. It definitely seems t oget louder as the oil gets hotter.
ahthud is offline
post #4 of 9 Old 07-24-2011, 7:36 PM Thread Starter
Any other ideas gents?
ahthud is offline
post #5 of 9 Old 07-25-2011, 3:17 PM
Timing chain tensioner? (CCT)
SandorPaull is offline
post #6 of 9 Old 07-25-2011, 4:29 PM Thread Starter
No its not a timing chain rattle, more a knock
ahthud is offline
post #7 of 9 Old 07-27-2011, 1:28 PM
Msyabe exhaust leak?
charles.scarlet is offline
post #8 of 9 Old 07-27-2011, 2:16 PM
Reputation Power: 26
Sounds like a rod bearing to me. Mine was doing that. I split the case and checked the bearings. Ended up replacing them all with the original size (the bearings were actually worn). Rechecked clearances and it was good.
The thing is you have to split the case to get to them, which sucks.
2002 CBR954RR, 1998 VFR800
Deadsmiley is offline
post #9 of 9 Old 07-27-2011, 4:26 PM
Who checked your valves? And how much did it cost?
ENGINE KNOCK NOISE KWIKKAR.WS Honda FireBlade 4 11-15-2010 9:14 AM
WHAT WOULD CAUSE ENGINE KNOCK deceptikon Honda FireBlade 7 05-24-2009 5:20 AM
929 engine knock/tick??? medicbaldwin Honda FireBlade 10 10-22-2008 8:45 AM
929 Engine Knock? ShadeZ Honda FireBlade 11 05-19-2006 12:18 AM
954 engine knock sullijs Honda FireBlade 12 11-26-2004 11:59 PM
