Lowering Footpegs on My '03 954 - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 07-23-2011, 7:08 PM Thread Starter
I'm 6 feet, 2 inches tall with a 34 inch inseam.
I'd like to lower the footpegs on my 954. I bought a 30 mm lowering kit from Wild Hair Associates. It's beautifully made and adjustable 6 ways to Sunday.
The problem is that the brake actuation rod doesn't have enough adjustment to be able to lower the brake pedal to be used with the new peg lowering kit - the rod is too short. And a longer rod would place the foot pedal way too high.
I understand that the pegs were raised on the '02 954 compared to the '01 929. The 929 pegs were lower.
Can the 929 peg hanger brackets be used on the 954?ll If so, how much lower are they?
Have you developed another way to lower the foot pegs on a 954?
Thanks for any thoughts or experience you my have.
Sandy
PegTest(Brake)small.jpg‎
NobleSandy is offline
post #2 of 4 Old 08-10-2011, 12:33 AM
Re: Lowering Footpegs on My '03 954
I think I see what you mean. Just a few ideas:
1) Maybe use 2 small brackets to move the master cylinder higher thus lowering the lever?
2) Have the lever professionally cut & welded lower near the pivot
3) Find a lever / master cylinder from another bike that works better
FYI - the footpeg brackets have different part #'s for the 929 & 954.
Keep us up to date; I was just considering lower pegs since my left hip has been sore when lifted midway like when on the bike.
Bob H. is offline
post #3 of 4 Old 08-11-2011, 6:20 PM Thread Starter
Bob H,
Thanks for your suggestions. I am measuring the dimensions for a possible new mounting bracket for the rear brake master cylinder. Moving that up would facilitate a longer adjustment rod so the rear brake pedal could be adjusted for a proper fit.
I think that the ideal solution would be to have custom mounting plates made for the foot control brackets. These would have many mounting points for the foot control brackets. This would maintain all OEM peg/pedal/lever/brake light switch relationships and would allow multiple locations for the foot peg/rider interface. In addition, it would move the assembly slightly outboard giving more clearance between the assembly and the exhaust mid pipe.
As an option, I've discovered foot peg lowering blocks (on VFR Discussion.com) that use the OEM foot pegs with the rubber inserts. They do not move the rider's feet outboard as do the Wild Hair pieces I mentioned in my previous e-mail. The Wild Hair units require the rider to turn his/foot inward to activate the brake. I understand that the VFRD pieces will fit all Honda sport bikes with the exception of some early VFR 750s. I'll tell you more about them as I do more research.
Sandy
post #4 of 4 Old 08-21-2012, 3:25 PM
Any word on this? I just took my new to me 900rr and my legs are a bit cramped.. not sure why I don't quite "fit" this bike.. my F4i was perfect sizing.. as with my FZ6 and R6. I just felt like my foot was just a shade too high.
rice_rocket is offline
VFR-ing my Blade - stage 1 lowering the footpegs Dangerous Des Honda FireBlade 35 07-20-2015 7:47 AM
Remove Footpegs fatbikez Honda CBR 600 3 03-16-2009 3:08 AM
rear footpegs millemart Introductions 0 11-13-2008 6:01 PM
Footpegs Question GXXRDRVR Honda FireBlade 1 08-12-2006 2:09 PM
Lowering Footpegs? moregrip Honda FireBlade 5 10-13-2004 4:55 PM
