After Pair Mod - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 07-24-2011, 8:23 AM Thread Starter
Reputation Power: 15
After Pair Mod
Had to do the Pair mod to install an "Autotune module"; so i got a pair of block off plates; took off the air box; plugged the hole in the air box that goes to the pair valve assembly, took every thing off but the valves themselves (i need the seal) and blocked every thing off. Now one thing i noticed afterwards (it's not performance related) its a slight rattle in the sound of the engine in low rpm that goes away beyond 2500 rmp; i should mention that i had the header removed and re-installed after welding the O2 sensor bung (i have a "Taylormade" exhaust; hence the hassle); do i have to be concerned or the change in sound is normal? Also It is running a bit rougher down low.
thanks guys.
abzeed is offline
post #2 of 4 Old 07-26-2011, 4:04 PM
Reputation Power: 9
Re: After Pair Mod
Mine has the same rattle, once I get paid 2500 it goes away. Not sure what its from. Almost sounds like the cam chain? Not too sure in all honesty.
livinloud11 is offline
post #3 of 4 Old 07-26-2011, 7:46 PM Thread Starter
Re: After Pair Mod
I didn't mention that my bike is a 2010 model with only 6000 Miles on it; and i didn't tamper with anything related to the cam chain; i suspect that the block-off plates are leaking; and because i didn't actually take the valves off; they are still working under vacuum in low revs and deceleration; i will be taking everything apart again ,remove the valves and re-seat the block-off plates, and see what happens.
abzeed is offline
post #4 of 4 Old 07-27-2011, 7:51 PM Thread Starter
Re: After Pair Mod
I was right; problem solved
abzeed is offline
What is PAIR mod? ridinred Aftermarket Perfomance Parts Reviews 11 01-05-2011 9:06 PM
pair mod help bc929 General Discussion 3 08-17-2009 12:30 AM
What exactly does a pair mod do and how do you do it? curt248 General Discussion 4 06-12-2008 1:32 PM
PAIR Mod- HELP! resuscit8u Honda FireBlade 6 08-29-2003 4:08 AM
