Fouling plugs again - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 07-24-2011, 12:16 PM Thread Starter
Fouling plugs again
I replaced all the plugs last fall. Fouled them again. Replaced FPR and plugs ran great for 2 months. Then again today misfiring. At a loss.
Hook954 is offline
post #2 of 16 Old 07-24-2011, 12:28 PM
Send a message via MSN to laomaoyhl
Re: Fouling plugs again
make sure your oil lever on the corrcect lever,oil lever too high will wet the ignition plugs,and then dirty the plugs and hard to fire.....
laomaoyhl is offline
post #3 of 16 Old 07-24-2011, 12:57 PM Thread Starter
Ok I will check.
Hook954 is offline
post #4 of 16 Old 07-24-2011, 1:19 PM
A new regulator or a secondhand one?
post #5 of 16 Old 07-24-2011, 1:33 PM Thread Starter
New from Ron Ayers.
Hook954 is offline
post #6 of 16 Old 07-24-2011, 2:03 PM
New from Ron Ayers.
Did you confirm the previous regulator had failed?
Have you checked if this one has?
post #7 of 16 Old 07-31-2011, 12:47 AM Thread Starter
I know this one has not. No i just replaced the previous one. I don't think it failed either.
Hook954 is offline
post #8 of 16 Old 08-04-2011, 12:43 AM Thread Starter
when i checked the plugs they are all black. Exhaust also has black on the tip. Is bike running too rich? The bike has a 1/2 Yosh system and previously had a 1/2 Ti-force.
Hook954 is offline
post #9 of 16 Old 08-04-2011, 2:55 AM
when i checked the plugs they are all black. Exhaust also has black on the tip. Is bike running too rich? The bike has a 3/5 Yosh system and previously had a 3/4 Ti-force.
How many mpg are you getting?
Are you running a PC?
What do 3/5 and 3/4 mean?
post #10 of 16 Old 08-04-2011, 8:16 AM Thread Starter
Sorry meant 1/2 systems. Gas light comes on about 130-132 miles. No PC
Hook954 is offline
post #11 of 16 Old 08-08-2011, 12:29 PM
Reputation Power: 11
Dont feel bad my gas light turns on when i have a full tank of gas. so i just watch my mpg. @ 140 i fill up at the most i normally do it at 100 just to be on the safe side And the thing about your plugs being black. I have herd that the moment that new plugs are put in and the bike turns on there black. Because of Fire! BUt yeah do you have a pc. make sure that you have the correct map i believe that its # 14
charles.scarlet is offline
post #12 of 16 Old 08-08-2011, 1:43 PM
If they're black then you're either burning oil or running way too rich.
I've pulled plugs out of engines after 30,000kms and they're a beautiful tan colour as they should be.
post #13 of 16 Old 08-09-2011, 12:17 PM
Thats what i think is going on just waiting for the check to come in so i can go get a custom dynoed map
post #14 of 16 Old 08-09-2011, 4:50 PM Thread Starter
No PC. I got the bike last Aug. meant to do a oil change and never got around to it. I didn't ride alot. Could old oil do it?
Hook954 is offline
post #15 of 16 Old 08-09-2011, 10:51 PM
If the oil is old or the wrong viscosity it will bypass the rings to be burned. Is it using any oil or blowing any smoke?
How many miles are on the oil now?
fouling plugs, 95 900rr diggercbr Honda FireBlade 2 05-16-2010 5:36 PM
F4i fouling 2 and 3 plugs and idle problem? 01nickypF4i General Discussion 15 03-27-2009 7:20 AM
Hi Everyone - New RC51 Owner with stalling and plug fouling issues RJ_RC51 Honda RC51 11 12-16-2007 7:00 PM
Sparkplug Fouling maniac121 Honda FireBlade 5 03-07-2007 10:51 PM
Honda Cbr 929 fouling plugs BUCKAS Honda FireBlade 6 05-24-2006 12:35 AM
