02 954 won't start - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 07-24-2011, 10:14 PM Thread Starter
02 954 won't start
Have fuel. Have injector pulse. Spark is there, but it doesnt "spark,spark,spark" when turning over. It sparks and then a few seconds later sparks again. I have bypassed the tip over sensor. HELP PLEASE GUYS!!
team50shop is offline
post #2 of 5 Old 07-25-2011, 5:26 AM
Re: 02 954 won't start
Tell us some more!
What is the history, its was working them what?
Check out the plug gaps is it sparking like this at all cyclinders?
Have you got good battery voltage?
CBRR is offline
post #3 of 5 Old 07-25-2011, 9:49 AM Thread Starter
Battery hooked up to jumper cables and a car. The bike was driven to NC last year then parked. Sat over winter and now no start. Yes the spark is like this on all 4 coils. I think it is the pulse generator, but not sure where it is or how to test it.
Thanks for the reply.
post #4 of 5 Old 07-26-2011, 4:28 AM
get some 'easy start' ether based fuel in a can;
see Starting Aids :: Repair & Maintenance :: Holts Auto
Take the tank off and squirt a bit in each carb. If its firing OK it will start for a bit on this. If you get no go, then you definatly have an igniction problem.
Make sure you have good plugs with corect gaps to start with.
If still no go, then you may well be correct, it will be either the pick up sensor, the ignitor or some wiring fault in between. but try the easy stuff first before ripping all to bits!
CBRR is offline
post #5 of 5 Old 07-26-2011, 9:01 AM Thread Starter
put some starter fluid down it already with brand new plugs and gap was correct. it still would not start. i just bought a ecm to see if thats what it is.
cant start, wont start shanelufc Honda CBR400RR 3 01-28-2011 3:44 AM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-19-2010 12:58 AM
'00 F4 - Won't Start, where do i start? cranks but doesnt fire. dunkd Honda CBR 600 7 07-30-2007 6:32 PM
Won't start... klind Honda CBR 600 23 04-12-2007 6:13 AM
cold start(how does your 954 start) JakeT Honda FireBlade 21 06-29-2005 12:01 AM
