954 won't start - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 07-28-2011, 6:20 PM Thread Starter
Reputation Power: 10
954 won't start
02 954 is not starting....fuel pump is not priming and my headlights aren't working either.... I was riding the bike earlier with no problems starting it.... I had this problem before but it started working again after I tinkered around a little bit..... Any suggestions would be greatly appreciated....
shane_ya_dig is offline
post #2 of 15 Old 07-28-2011, 6:24 PM
Reputation Power: 78
Re: 954 won't start
Check the 30 amp fuse, or look for a lose/broken connection inside the right side switch housing.
BurtonF166 is offline
post #3 of 15 Old 07-28-2011, 6:44 PM Thread Starter
Re: 954 won't start
Right side housing is good... Where is the 30 amp fuse?
post #4 of 15 Old 07-28-2011, 6:47 PM
Re: 954 won't start
Right by your battery, its part of the starter relay.
post #5 of 15 Old 07-28-2011, 7:10 PM Thread Starter
Re: 954 won't start
By the way... The starter switch works and the horn works....
post #6 of 15 Old 07-28-2011, 7:16 PM Thread Starter
Re: 954 won't start
The 30 amp fuse is good
post #7 of 15 Old 07-28-2011, 7:26 PM Thread Starter
Re: 954 won't start
Turn signals are not working either
post #8 of 15 Old 07-28-2011, 7:43 PM
Reputation Power: 9
Re: 954 won't start
Any lights on dashboard? Any error codes? Get a haynes manual or equivalent and check your all relays and wiring... Any chance you can hook up ECM from working bike?
929lad is offline
post #9 of 15 Old 07-28-2011, 8:38 PM
Re: 954 won't start
What kind of tinkering did you do before to remedy this problem?
post #10 of 15 Old 07-29-2011, 12:09 PM Thread Starter
Re: 954 won't start
The cluster lights up fine, no error codes... Imma prolly end up stripping the bike down and see where the headlight wiring meets with the engine stop switch wiring (((
post #11 of 15 Old 07-29-2011, 12:12 PM Thread Starter
Re: 954 won't start
Last time this happened was right after I installed my gear shift indicator, so I had the gas tank up and plastics off.... So I was just messin with random wires and plugging and unplugging things.... What fixed it last time was I pushed the engine start button and gave the bike gas and reved it up and then it was working after that.... Unfortunately that is not helping this time
post #12 of 15 Old 08-06-2011, 11:41 AM Thread Starter
Re: 954 won't start
Found the problem.... I'm not sure what wire it is but it was melted and I replaced it and everything is great!!!
post #13 of 15 Old 08-06-2011, 7:00 PM
Re: 954 won't start
I'M HAVING THE SAME PROBLEM. WHERE WAS THAT WIRE YOU FOUND? I JUST TRADED A 01 MUSTANG GT FOR A 02 954. AT TIME I THINK I MAY HAVE MESSED UP.
damnright is offline
post #14 of 15 Old 08-06-2011, 7:56 PM Thread Starter
Re: 954 won't start
I'll post a picture when I get home
post #15 of 15 Old 08-07-2011, 12:19 AM
Re: 954 won't start
well after cussing up a storm and many bolts later... i got my baby back working with lights even. thank you any way.
cant start, wont start shanelufc Honda CBR400RR 3 01-28-2011 3:44 AM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-19-2010 12:58 AM
Will Not Start Dauwsy Honda CBR 600 5 04-15-2008 12:10 PM
'00 F4 - Won't Start, where do i start? cranks but doesnt fire. dunkd Honda CBR 600 7 07-30-2007 6:32 PM
cold start(how does your 954 start) JakeT Honda FireBlade 21 06-29-2005 12:01 AM
