2008 Blade Help!!!!!!!!!!! - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 07-29-2011, 3:22 PM Thread Starter
Reputation Power: 15
Here's my dilemma 2008 CBR1000RR cold start idling issue once it warms to 182 degrees it's fine you can shut it off and it fires right back up and idles perfectly and steady.
Things I've done and replaced at 32,000 miles.
Replaced ECT sensor and thermostat.
Replaced plugs
Replaced IACV
Replaced IAT sensor.
Unplugged PC111 still have the issue
Checked for vacuum leaks..None.
Replaced battery.
My worst fear is that mine is an oil burner a quart every 500 miles now, bike still runs strong next stop will be a compression check that's causing it but I don't think that's it.
redrider67 is offline
post #2 of 2 Old 07-29-2011, 7:59 PM
Re: 2008 Blade Help!!!!!!!!!!!
check you throttle blades and bores make sure there clean of carbon build up..same with you intake valves..
chriswtx is offline
wheels for blade 2008 Blackadder Honda FireBlade 16 12-03-2009 1:31 PM
2008 'blade - now what? Marcbc Honda FireBlade 5 08-10-2009 4:18 AM
Bridgestone BT-015's (2008/09 Blade) GazRR Honda FireBlade 53 04-06-2009 3:24 PM
2008 blade. silverh Honda FireBlade 0 02-05-2009 10:05 AM
2008 blade parts help HataErasa Honda FireBlade 3 05-06-2008 12:33 PM
