Damn HTEV.. - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 08-12-2011, 1:56 AM Thread Starter
Reputation Power: 9
Damn HTEV..
So I have a 2000 cbr 929rr. My HTEV disconnected. I had the flapper still connected though. It recently started giving me idle problems along with bogging down while trying to move. I disconnected the flapper and removed it, and I also put the valve in to the full open position. It seems to be a little better but im not completely sure and won't know until tomorrow. Any tips?
Also, what is the plug on the outside if the airbox on the back right of it? the one connected to the actual airbox. Thanks.
livinloud11 is offline
post #2 of 5 Old 08-12-2011, 2:00 AM
Reputation Power: 11
Re: Damn HTEV..
Air sensor
charles.scarlet is offline
post #3 of 5 Old 08-12-2011, 10:14 AM
Quoted: 11 Post(s)
Reputation Power: 57
Re: Damn HTEV..
My advice is to fix the htev so its working normal. You gain nothing by removing or disconnecting it. Your bike will run better with it working. As for the flapper in the airbox you gain nothing there either except for increased intake noise by removing it.
SOLD: 03 CBR954
backdoc is offline
post #4 of 5 Old 08-12-2011, 10:19 AM
Re: Damn HTEV..
Checked the vacuum line on the fuel pressure regulator?
Intake Air Temperature sensor - if it's not working you should have a flashing MIL on the dash.
post #5 of 5 Old 08-12-2011, 10:48 AM Thread Starter
Reputation Power: 9
Re: Damn HTEV..
So i guess its working, it just seemed like it started and purred perfectly when I started it with that disconnected. And im not too sure where the fuel pressure regulator vacuum line is. Ill check that next if you point me in the right direction
Damn Foxes! jimblade General Discussion 17 07-29-2005 1:02 AM
DAMN..... ConqSoft Off-Topic 17 12-16-2003 6:37 AM
Damn deez Road Racing: Professional 8 11-18-2003 2:46 PM
THE DAMN CAT GAZZERUK Off-Topic 0 11-09-2003 7:01 PM
Damn! Ridin Red in MN Honda FireBlade 34 05-13-2003 1:40 PM
