04-05 Fireblade yoke width please :-) - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 01-13-2012, 11:27 AM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 77
Hi, I need to know the distance between the forks on a 04-05 blade please if someone has one. Heres a pic of the distance im refering too. I know the steering damper is in the way but a rough estimate, the 929 is about 165mm
Thanks
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #2 of 7 Old 01-14-2012, 3:59 AM
Re: 04-05 Fireblade yoke width please :-)
Thanks
929/954 and 1000RR should be the same. They run the same axle.
post #3 of 7 Old 01-14-2012, 8:08 AM Thread Starter
Quoted: 4 Post(s)
Thanks Blaceracer, I know the 08 cbr1000 is diffrent so just wanted confirmation on the ealier ones. I want to check the caliper spacing is going to work with the 929 yokes
post #4 of 7 Old 01-14-2012, 8:12 AM
The wheel, discs and axle are interchangeable from '00-'07 so I can't imagine it being a problem. Fork offset may vary of course.
What spacing is the '08-onwards?
post #5 of 7 Old 01-14-2012, 8:56 AM Thread Starter
Quoted: 4 Post(s)
great that good news Bladeracer put my mind at rest. The only reason I know the 08 is diffrent is because I read there have been problems with caliper disk aligment when fitting an RC51 front wheel to the 08, the disk is not centralised in the caliper.
post #6 of 7 Old 01-22-2013, 2:14 PM
Reputation Power: 9
Did you ever get a measurement on this?
Crom is offline
post #7 of 7 Old 01-22-2013, 6:36 PM
What measurement do you need?
Fork / Yoke help please Lambchops Honda FireBlade 0 11-02-2011 7:08 AM
help top yoke needed ketkid21 Wanted 0 08-09-2011 5:34 AM
1996 fireblade top yoke, will it go on a 2001 929 fireblade ahoulding Honda FireBlade 1 10-31-2010 10:27 AM
Rear tire width? NWOleman Honda Interceptor / VFR 2 04-04-2007 11:58 AM
'01 929 Axle width???? Xfirebladeowner Honda FireBlade 0 12-06-2003 12:41 PM
