2010 Fireblade Sprockets - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 01-18-2012, 3:58 PM Thread Starter
Hi all
I have just fitted new sprockets to my 2010 Fireblade, does anyone know what the torque in Newton Metres for the front sprocket nut and the rear sprocket nuts should be please. I don’t have a manual; I could do with the ‘pdf’ if anyone can share, ‘pretty please’. Also do any of you know how the bike will now perform due to extending the rear wheel by 5mm, as a result of 15T front and 42T rear? The last bike I dropped a tooth from the front was a Kawasaki ZX636R, it increased the acceleration, but it run out of poof easily, I did not really notice any chassis changes though!
Thanks in advance.
............ Hoody
Hoody is offline
post #2 of 8 Old 01-18-2012, 6:22 PM
Re: 2010 Fireblade Sprockets
Originally Posted by Hoody View Post
Hi all
Thanks in advance.
............ Hoody
No difference at all. You get more than 5mm just from chain adjustment.
post #3 of 8 Old 01-18-2012, 6:44 PM Thread Starter
Hi Bladeracer
By dropping a front tooth, it has moved the rear wheel back 5mm due to chain tension.
Any torque figures?
......... Hoody
Hoody is offline
post #4 of 8 Old 01-18-2012, 6:47 PM
Hi Bladeracer
Any torque figures?
......... Hoody
Yes, and as the chain wears it'll move back another 15-20mm - all with no noticeable difference to the handling.
Torque figures?
Changing the gearing does not change the power or torque of the engine.
post #5 of 8 Old 01-18-2012, 6:53 PM Thread Starter
He he, I was after the torque figures for the front bolt that holds the sprocket on and the rear nuts that hold the rear sprocket on.
As for the bikes torque figures, I know exactly what they are........ scarey
.......... Hoody
Hoody is offline
post #6 of 8 Old 01-18-2012, 7:00 PM
.......... Hoody
Oops :-)
Front is 54Nm, rear are 64Nm.
post #7 of 8 Old 01-18-2012, 7:03 PM Thread Starter
Thank you kind sir
Just need to find a workshop manual now
.......... Hoody
Hoody is offline
post #8 of 8 Old 01-18-2012, 7:43 PM
Quoted: 120 Post(s)
Reputation Power: 198
.......... Hoody
Even when bladeracer makes a mistake, it's a decently smart one.
jondog9 is offline
Fireblade 2010 oil leak nomadicbiker Honda FireBlade 4 10-12-2011 7:15 PM
what exhaust for 2010 fireblade? bananaman Aftermarket Perfomance Parts Reviews 6 05-21-2011 12:14 AM
2010 Fireblade- CBR 1000 RR abzeed Honda FireBlade 10 09-17-2010 6:30 AM
fireblade security (2010) mole10r General Discussion 11 02-11-2010 3:30 AM
2010 Fireblade piccies .... sync24 Honda FireBlade 14 09-05-2009 10:26 AM
