954 fuel pump - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-21-2012, 10:25 AM Thread Starter
954 fuel pump
The fuel pump quit coming on when the key is turned on and switch is in run position. There is no fuse. I've checked the run/stop switch, tilt switch. Anyone know how to check the relay or the pump itself?
Any info appreciated.
Keith
CBRflyr is offline
post #2 of 6 Old 01-21-2012, 11:33 AM
Re: 954 fuel pump
Keith
Connect 12V power directly to the pump connector.
It it still doesn't run then probe the wires where they enter the pump.
If there's still nothing then you will have to remove the pump to apply power directly to the pump.
If it still doesn't work then you need a new pump.
post #3 of 6 Old 01-21-2012, 11:35 AM
Re: 954 fuel pump
I forgot to ask the obvious.
The engine does turn over just fine?
post #4 of 6 Old 01-21-2012, 11:53 AM Thread Starter
Re: 954 fuel pump
Yes, it does turn over. Is it possible that the relay is bad or the tilt sensor? Thanks
CBRflyr is offline
post #5 of 6 Old 01-21-2012, 11:56 AM
Re: 954 fuel pump
Sure it's possible.
If the pump works when you apply power to it then you'll have to work back through the circuit to the battery until you find where the power is stopping.
post #6 of 6 Old 07-04-2012, 7:34 PM
Quoted: 4 Post(s)
Reputation Power: 9
Re: 954 fuel pump
Any updates????
"Blade" doyou have a reverse order of electrical flow from pump?
ande6009 is offline
Fuel Line connection to Fuel Pump kenestle Honda FireBlade 14 09-20-2010 4:49 PM
Fuel pump or clogged fuel lines??????? pizzario69 General Discussion 1 09-28-2009 5:16 PM
F3 Fuel Pump ?? WhitsRC Honda CBR 600 1 07-29-2009 2:37 AM
Fuel Pump or.... Waterchestnut Honda FireBlade 2 07-04-2009 6:24 PM
Fuel Tank / Fuel pump seal ugt33 Honda RC51 0 10-24-2008 3:13 AM
