929 not starting help... - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-22-2012, 8:04 PM Thread Starter
So I have a 2001 929, stock except for baffle fix, air filter, and pipe. It has 30k on it. Recently I started having to put it on a charger every night to ensure it would start. Now even with a jump start it won't start. Cranks good but fuel pump not kicking on....ideas please?
Feelininvincibl is offline
post #2 of 6 Old 01-22-2012, 10:56 PM
Re: 929 not starting help...
If it's a problem that's gotten worse over time then perhaps the fuel pump has died.
Do you use the kill switch regularly?
post #3 of 6 Old 01-23-2012, 8:09 AM Thread Starter
Yes I do use the kill switch, every time I shut down.
post #4 of 6 Old 01-23-2012, 8:11 AM
Don't, it's not designed for that.
My guess is you need a new kill switch.
post #5 of 6 Old 01-23-2012, 10:01 AM Thread Starter
Is it possible that the heavy humidity got in under the switch and is preventing pump start up?
post #6 of 6 Old 01-23-2012, 10:04 AM
If it's very worn I guess that wouldn't help.
Bypass the switch to confirm it is actually the problem.
Starting problems, turns over but only starts with starting fluid myfirstcbr600 Honda CBR 600 13 11-20-2009 7:53 PM
still not starting borris Honda CBR400RR 21 10-01-2008 2:23 AM
RC 51 not starting groundN'ponder Honda RC51 7 09-30-2006 12:58 AM
Ok, Now I am starting to believe that.... QuikMike Politics 61 06-20-2006 12:10 AM
starting martin929 Honda FireBlade 17 02-09-2006 1:03 AM
