06 1000rr tail on 929 mod - Honda Motorcycles - FireBlades.org
post #1 of 51 Old 01-30-2012, 4:06 AM Thread Starter
Reputation Power: 23
Friends with __z__, got the idea to put a 1000rr tail on my 929 from him.
I got a cracked rr tail off e-bay for $40 and plastic welded it with my $4 soldering iron (saving $160 from having to buy mint used tail).
Then I took my old 929 tail off and set the rr tail on and found the stock subframe would have to be altered.
Here's what I kinda want the end result to look like (probably not this paint job).
I cut off the lower support so then I could work on bending what remained of the subframe (the end) up to become a support.
Here's the first bend and how I did it (strap the subframe, use pry bar, and heat)... Obviously be careful when bending aluminum (it doesn't get red hot like steal) Hold constant pressure as you lift up and heat the area... don't use more heat than you have to and heat evenly.
Here's some seat support I made... riviting things in for now before I weld it all up... YES the bends are strong.
MattCBR is offline
post #2 of 51 Old 01-30-2012, 4:14 AM Thread Starter
Re: 06 1000rr tail on 929 mod
It's an on going project that I'm in the middle of so I'll post updated pics as I go along. If anyone wants more detailed pics or how too explanations just ask and I'll post them up... I'm "Matt Cbr" on facebook also works.
Thanks!
MattCBR is offline
post #3 of 51 Old 01-30-2012, 4:23 AM
Quoted: 4 Post(s)
Reputation Power: 77
looking good Matt
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #4 of 51 Old 01-30-2012, 4:26 AM
You are going to put a lower brace back in aren't you?
I can't imagine that setup being able to support a rider and pillion.
I made a single-seat subframe for my 929 and still used a lower brace.
post #5 of 51 Old 01-30-2012, 5:13 AM Thread Starter
Yep, going to use a lower brace for sure... I got it ready, just need to bolt them up... it'll look like this:
(black lower brace re-located to follow the lines of the tail)
MattCBR is offline
post #6 of 51 Old 02-01-2012, 4:08 AM Thread Starter
Finally saw some 1000rr vents for less than $30 on ebay... got these for $12 shipped
Also got some sanding done on the Tail... just thought I'd stop mid-way through and show when enough sanding is done... I use 120 to get the clear coat off.
Speaking of body work... I bought 6 sheets of this 12"X12" ABS plastic 1/8" thick to make a new custom undertail and battery tray.
Lastly, I got my 1000rr tail light working... the little green dot above the tail light is my programable strobe flasher (when the brakes are applied it flashes a pre-set ammount of flashes at a pre-set speed)
MattCBR is offline
post #7 of 51 Old 02-03-2012, 10:14 PM
Reputation Power: 10
Nice look forward to the finished pics
sj66 is offline
post #8 of 51 Old 02-04-2012, 5:53 PM
Reputation Power: 17
Just my opinion but I think the silver tail with RR looks stunning!
cheers
Simon
r15suk is offline
post #9 of 51 Old 02-07-2012, 3:52 AM Thread Starter
cheers
Simon
Thanks, yep that is just some photo shop work of what I want to end up with
MattCBR is offline
post #10 of 51 Old 02-07-2012, 3:52 AM Thread Starter
Got the other 1000rr tail support brace built now I can do my undertail and the lower supports.
Bolted my vents on... good thing I have a few extra CBR bolts and such.
Looking better than the wide open holes for sure
MattCBR is offline
post #11 of 51 Old 02-11-2012, 2:27 AM Thread Starter
A lazy biker would buy an undertail for $100. A normal wrencher would bolt up a flat piece of metal for an undertail. A wrencher who cares makes his own curved piece from ABS to weld it flush in place
In the middle of plastic welding it on... I used 1/8" thick ABS because I knew I was going to have to do a ton of sanding to get the lumps out... plus it's nice and strong for an undertail.
MattCBR is offline
post #12 of 51 Old 02-13-2012, 7:01 PM Thread Starter
Finished plastic welding this part.
MattCBR is offline
post #13 of 51 Old 02-16-2012, 7:43 AM Thread Starter
Finished cutting up the lower braces:
MattCBR is offline
post #14 of 51 Old 02-16-2012, 7:47 AM Thread Starter
Finished plastic welding this part. While I was at it I wrote a How to on plastic welding and preping for paint: https://www.fireblades.org/forums/art...aint-prep.html
MattCBR is offline
post #15 of 51 Old 02-18-2012, 8:38 AM Thread Starter
Beefing it up before painting it.
MattCBR is offline
Tags
1000rr tail , cbr 929 , custom undertail , plastic weld , subframe mod
929rr with 1000rr tail custom tail light set up __Z__ Honda FireBlade 7 03-09-2011 10:31 AM
TO THE GUY WHO PUT THE 1000RR TAIL ON HIS 929 pwozzy Honda FireBlade 7 05-04-2010 11:16 PM
954 with 1000RR tail jcvd666 Honda FireBlade 14 08-30-2008 3:46 AM
How is the UFO tail light for the 1000rr? Brooklyn RR Vendor / Seller / Dealer Reviews 0 01-10-2008 10:37 AM
Anyone with a 06 1000RR and a Jardine under tail? trbo2nr Honda FireBlade 8 08-27-2006 6:08 PM
