107 octane - Honda Motorcycles - FireBlades.org
post #1 of 18 Old 01-31-2012, 4:45 PM Thread Starter
107 octane
Would it help to run 107 octane in A 99 cbr 900
wyle00069 is offline
post #2 of 18 Old 01-31-2012, 4:50 PM
Re: 107 octane
Help in what way exactly?
I can't think of any advantage to using it but it may have some additives that make it worthwhile for engine life and fuel economy perhaps.
post #3 of 18 Old 01-31-2012, 4:56 PM Thread Starter
Re: 107 octane
Give it more power. Or clean out any gunk or is it better to use a cleaner additive or pull the carb out and clean it ? I replaced the plugs and it hesitates about 4-5k rpm
post #4 of 18 Old 01-31-2012, 4:59 PM
Re: 107 octane
No, higher octane does not increase power.
It allows you to run higher compression and that gives you more power.
Did it hesitate before you replaced the plugs?
post #5 of 18 Old 01-31-2012, 5:00 PM Thread Starter
Re: 107 octane
Yep
post #6 of 18 Old 01-31-2012, 5:29 PM
Reputation Power: 54
Re: 107 octane
Are you concerned that your carbs may be dirty? It sound as though you are. I'm not sure that would clean your carbs, but I know that there are additives that will loosen up the varnish. Burning that varnish through the engine probably isn't going to do it any favors though.
Rendell is offline
post #7 of 18 Old 01-31-2012, 5:41 PM
Re: 107 octane
i would try it its not gonna hurt anything and sounds easier than pulling the carb
opey954 is offline
post #8 of 18 Old 01-31-2012, 5:46 PM
Re: 107 octane
Some fuels can cause problems, especially racing fuels like methanol. If you don't know for sure that it's okay don't use it.
post #9 of 18 Old 01-31-2012, 7:46 PM Thread Starter
Re: 107 octane
Thanks its retarded realy research could have avoided a dumb question I thank you for your help
post #10 of 18 Old 02-01-2012, 9:01 PM
Re: 107 octane
Too much octane can. Be a bad thing. It will burn cooler. So much cooler that you will loose power & possibly cause carbon buildup.
daveblank is offline
post #11 of 18 Old 04-18-2012, 8:07 AM
Re: 107 octane
Yeah depends what you after.. but I found too much octane was actually giving a slight ping 07 1000RR and awe-full down low.. was running 98 went down to 95 and bike is a lot quieter but funnily enough a more cleaner responsiveness..
horse_power777 is offline
post #12 of 18 Old 04-18-2012, 11:06 AM
Reputation Power: 11
Re: 107 octane
High octane gas burns slower, thus preventing detonation.
However you don't need to run more than 87 in your 900rr. I like to run 91 since it's only a few dollars more and my bikes seem to run better on premium fuel. Race fuel is really only required for high compression engines, or turbo bikes, etc.
slothman is offline
post #13 of 18 Old 04-18-2012, 11:07 AM
Re: 107 octane
Clean the carb jets (all pilots and mains) and see if that fixes the problem. Also check and make sure the filter is clean.
slothman is offline
post #14 of 18 Old 04-18-2012, 12:50 PM
Reputation Power: 113
Re: 107 octane
The best fuel for your bike is the fuel specified in the manual.
Higher octane DOES NOT equal more power, unless you're doing things like increasing compression or using a turbo. Even then, it's not the octane that's increasing the power, it's the modifications. Octane SLOWS DOWN the fuel burn, and helps to reduce or eliminate knock.
Sky91 is offline
post #15 of 18 Old 04-18-2012, 1:58 PM
Re: 107 octane
Higher octane provides only one advantage - it can sit for longer before it becomes low octane.
But outside of the US the top-tier fuels have a bunch of additives that make them very worthwhile, in particular for engine life and fuel mileage.
I run 98RON in all my engines. I had cause to open up a car engine 60,000kms since I built it that's been run exclusively on 98 and the engine was spotless, so I intend to continue running it.
What octane for 954rr SquireSCA Honda FireBlade 84 03-06-2008 3:14 PM
110 Octane Bryce Auten General Discussion 19 07-18-2006 1:11 AM
What Octane to use? Repeater General Discussion 16 09-06-2005 12:22 PM
What % octane for u? Hellfire666 Honda FireBlade 60 05-17-2004 12:35 AM
gas octane? jerseydrew Honda FireBlade 50 07-18-2003 6:51 PM
