929 firing on three cylinders - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 02-18-2012, 5:18 AM Thread Starter
Reputation Power: 15
Hi there
just got a 929 running again after about 4 years. New ECU, fuel pump, all major service stuff. Starts and ticks over well but when riding lacks power and sounds as if it's only firing on 3. Suspect a duff coil. Any thoughts?
Thanks
jtree03 is offline
post #2 of 11 Old 02-18-2012, 5:52 AM
Re: 929 firing on three cylinders
Originally Posted by jtree03 View Post
Hi there
Thanks
Fuel pressure regulator perhaps.
post #3 of 11 Old 02-20-2012, 8:59 PM
My 954 dropped to 3 and it turned out to be a fouled plug.
Bigmaxy is offline
post #4 of 11 Old 02-21-2012, 4:53 AM
Reputation Power: 23
You can find out which cylinder after the bike is running (not even a minute) and feel the headers the second you start the bike... keep touching each one until you notice one that is staying colder than the others (that's the one not running obviously).
Then you can shut the bike off and try to isolate why that cylinder isn't running... think Air, Spark, Fuel
GL!
MattCBR is offline
post #5 of 11 Old 05-15-2012, 11:02 AM
kinda sounds like my 929. It starts right up but it takes couple seconds for the last cylender to kick in. i put new plugs and k & n air filter on it. ran great until last nite it was boggy and really choppy. But if i take it out a get on it it runs better. dont no whats going on. It runs rich to.
tyler1983 is offline
post #6 of 11 Old 05-15-2012, 11:04 AM
But you've already checked the fuel pressure regulator?
post #7 of 11 Old 05-15-2012, 11:31 AM
Check th fuel pressure regulator like bladeracer says. Mine went bad not too long ago an it caused a rough an rich idle but once I got riding it wasn't noticeable.
How can u tell th last cylinder isn't firing from th get go?
crazie929 is offline
post #8 of 11 Old 05-15-2012, 1:15 PM
Reputation Power: 11
first check to see if it's getting spark.
slothman is offline
post #9 of 11 Old 05-16-2012, 11:18 PM
Sorry i have been really busy. But I was able to work on my bike. I checked the fuel pressure regulator and when i pulled the vacumm hose off the regulator fuel came out. Im guessing its bad. Im smelling alot of gas when the bike is running.
post #10 of 11 Old 05-17-2012, 12:16 AM
Yep, you need a new FPR.
post #11 of 11 Old 05-17-2012, 10:34 PM
I got a FPR ordered. I really thank you guys for the help.
Not firing on all cylinders westley Honda CBR400RR 8 09-26-2011 3:04 PM
CBR900RRT firing on 2 cylinders Dave the Blade Honda FireBlade 4 03-02-2011 4:47 PM
03 954 only firing on 2 cylinders ?? jnutz1 Honda FireBlade 13 06-04-2009 1:15 PM
RE:CBR400 - one of the cylinders not firing right - advise please! marty_400 Honda CBR400RR 29 09-12-2008 4:29 AM
Two outside cylinders not firing. adrenalis Honda FireBlade 10 08-10-2008 10:36 AM
