929 - best value performance mods? - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 04-11-2012, 1:33 PM Thread Starter
Reputation Power: 15
I have a totally stock 929 - standard can, airbox flapper, exhaust valve etc. What's the best thing to do first to improve performance? Aftermarket can?
jtree03 is offline
post #2 of 9 Old 04-11-2012, 2:01 PM
Reputation Power: 55
Re: 929 - best value performance mods?
full exhaust, power commander, remove flapper, custom map. Pretty much all at once IMO
52brandon is offline
post #3 of 9 Old 04-11-2012, 4:02 PM
Th flapper mod is th most economical since it doesn't cost to remove th parts. A power commander would b th first thing to buy. It improves response at low rpms.
crazie929 is offline
post #4 of 9 Old 04-11-2012, 4:14 PM
Reputation Power: 29
change the gearing before spending hundreds. -1 tooth on front sprocket or or try +2 teeth on rear or both, will give much more acceleration but higher revs. Doing either will also give lower down pulling power (torque) you can then change the other sprocket as well. It is cheap to do and easily removed if not wanted. It will affect your speedo & mileometer though.
PEM-954 is offline
post #5 of 9 Old 04-11-2012, 5:05 PM
Reputation Power: 113
That's what Speedohealers are for
Sky91 is offline
post #6 of 9 Old 04-12-2012, 1:09 AM
15 tooth front sprocket.
post #7 of 9 Old 04-12-2012, 1:11 AM
Hmmm...Speedohealers are more for the people that can't do some simple math in their head actually ;-)
post #8 of 9 Old 04-12-2012, 5:34 AM
Not really. I ran 1-/+2 on my F4i for some time, which put the speedo way out of whack. What's the point in having an inaccurate speedo, as well as adding lots more miles to the odometer than you've actually covered?
Sky91 is offline
post #9 of 9 Old 04-12-2012, 6:17 AM
The speedo is inaccurate whether you alter your gearing or not, a speedohealer doesn't make it any more accurate, it just gives you a different number to look at.
The mileage is irrelevant other than making your maintenance intervals a little shorter - not a bad thing.
Performance mods? bc36 General Discussion 11 05-14-2010 7:31 PM
Performance mods Alkalineade Honda CBR400RR 0 03-04-2009 9:30 AM
Performance Mods 2004 1000RR Blade a1120028 Australia 20 10-25-2007 4:46 AM
performance mods? bdropped Honda CBR 600 0 07-29-2006 9:24 PM
New 954 Performance Mods? larddog954 Honda FireBlade 14 06-18-2003 7:40 AM
