93 cbr 900 cyl 1&2 wont fire - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 04-15-2012, 9:16 AM Thread Starter
cylinders 1 and 2 will not fire has spark and will backfire through carb. bike will run on 3 and 4. carbs are done and it did run before storage for winter. any help would be greatly appreciated.
jamslo is offline
post #2 of 16 Old 04-15-2012, 9:57 AM
Re: 93 cbr 900 cyl 1&2 wont fire
Do they fire if you spray starter fluid into them?
My guess is the carbs need cleaning due to sitting for several months.
post #3 of 16 Old 04-15-2012, 11:13 AM Thread Starter
no they dont fire with starting fluid. the carbs are new and cleaned just to make sure. only 3 and 4 will fire , so it appears the coils would be good as those cylinders fire on opposite coils if im correct
jamslo is offline
post #4 of 16 Old 04-15-2012, 11:21 AM
You said that you have spark but the two cylinders aren't firing - do they have spark or not?
If they have then the coils are fine.
Why did you buy new carbs for it if it ran fine before winter?
Nothing else has been messed with since the last time it ran fine?
post #5 of 16 Old 04-15-2012, 11:41 AM Thread Starter
yes all cylinders have spark however 1 and 2 only backfire thru carbs. a mouse got in air box and made a nest since bike only has side stand all the mouse pee ran to #1 carb and ruined it, tried everything to clean it but its just to corrosive and ruined carb so bought another set. do you know how many kv the spark should be? nothing has been changed since it was stored. i put new plugs in cleaned tank, lines etc.
jamslo is offline
post #6 of 16 Old 04-15-2012, 11:18 PM
mouse pee ruins carbs??: crap:
jasonsr 740 is offline
post #7 of 16 Old 04-15-2012, 11:51 PM
Okay, secondhand carbs then.
And you disassembled and cleaned them thoroughly and made sure that carb cleaner and compressed air passes through all the orifices as it should?
Are you using fresh fuel?
But it shouldn't be firing back through the carb if combustion is occuring when the intake valve is closed.
Are the carbs fully inserted into the manifolds and the clamps tight?
post #8 of 16 Old 04-16-2012, 4:54 AM
Clean carbs mate
maciejszumny is offline
post #9 of 16 Old 04-16-2012, 2:38 PM
Reputation Power: 11
I agree with the others...you have spark, so the problem is definitely the fuel. Take the carbs off again and clean them one at a time, and pay special attention to the main jets and the pilot jets.
BTW- I hope you killed that RAT bastard !
slothman is offline
post #10 of 16 Old 04-17-2012, 12:29 PM Thread Starter
Ok thanks guys
jamslo is offline
post #11 of 16 Old 04-25-2012, 12:34 PM
any updates ?
slothman is offline
post #12 of 16 Old 04-26-2012, 9:38 AM Thread Starter
No change still won't fire on 1&2 not even w starting fluid. Carbs are clean has spark carbs are tight
jamslo is offline
post #13 of 16 Old 04-26-2012, 9:51 AM
Have you checked valve clearances or done a compression test?
post #14 of 16 Old 04-26-2012, 11:25 AM
how could you be getting spark and its still not firing with starter fluid? check your plugs leads etc. is the wires to the coils packs in the correct order
canry31 is offline
post #15 of 16 Old 04-26-2012, 11:26 AM
If it doesn't have compression it won't fire.
CBR600FX WONT FIRE AntCBR600FX Honda CBR 600 1 09-29-2012 1:21 PM
954 WONT FIRE clem3 Honda FireBlade 5 12-26-2009 11:13 AM
f4 wont fire at all ktm851 Honda CBR 600 4 10-29-2007 8:49 PM
954 wont fire walid Honda FireBlade 5 05-16-2007 6:55 PM
