Engine shuts off when i turn right. - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 04-24-2012, 12:05 PM Thread Starter
Hi i'm new to the cbr scene and I have a problem with my 1995 900rr. when I turn my handle bars right the engine shuts off when I turn it back to the left and start it, it runs just fine. This all of a sudden happened and I dont know if their is a sensor or a loose wire im just missing.
seabeemarine is offline
post #2 of 15 Old 04-24-2012, 12:25 PM
Reputation Power: 113
Re: Engine shuts off when i turn right.
I'd be looking at the kill switch wiring. Is anything being pulled tight?
Sky91 is offline
post #3 of 15 Old 04-24-2012, 12:26 PM
Reputation Power: 46
check your cable lengths, but did you work on it lately before it happened?
noahb is offline
post #4 of 15 Old 04-24-2012, 12:32 PM Thread Starter
none of the wires are getting pulled. I did mess with the rectifier wires because one of them got frayed and i just cut it, soldered it, and taped it up. other than that i havent done anything.
post #5 of 15 Old 04-24-2012, 3:30 PM
If the electrics stay on then I'd be looking at the kill switch wiring.
post #6 of 15 Old 04-24-2012, 4:23 PM
Quoted: 2 Post(s)
Reputation Power: 15
mine did something very similar, it ended up being one of the 4 ignition wires from the key cylinder. in fact i have had to fix two of those 4 wires over the years, they got pinched by the triple clamps and steering stops.
packman5280 is offline
post #7 of 15 Old 04-24-2012, 5:07 PM
I've had the same problem before with ignition switches but you usually lose all power including the dash and lights.
post #8 of 15 Old 04-24-2012, 5:55 PM
Quoted: 2 Post(s)
mine was intermittent, and in the middle of the day to a new rider, i couldn't tell so easily that the whole thing was turning off, i was just kinda trying not to wreck. but yeah, the whole thing would shut off, lights and all, till i turned it back then everything came back on.
post #9 of 15 Old 04-25-2012, 12:17 PM Thread Starter
Everything else stays on its just the engine that shuts off. Im going to check the ignition cylinder wires and see if it is it. Would my rectifier have anything to do with it not starting? Because now it wont even start now. It gets really hot.
post #10 of 15 Old 04-27-2012, 9:53 PM
I have the same problem with you now, and do not know how to switch it.
caslolan is offline
post #11 of 15 Old 04-28-2012, 2:21 AM
mine use to cut out when riding..later found out it was the v sensor..everytime i leaned to one side the v sensor was telling the bike it was on it's side and cut all power...get back straight and started again..
webskie34 is offline
post #12 of 15 Old 04-30-2012, 3:40 PM
perhaps your tipover switch is only wearing one shoe... and been drinking... causing it to lean to the right... sorry, i've had a lot of coffee today...
praylood_93 is offline
post #13 of 15 Old 04-30-2012, 4:07 PM
Quoted: 2 Post(s)
do the older blades (93-99) even have a tipover switch?
post #14 of 15 Old 04-30-2012, 5:16 PM
how about you start your bike leave it in neutral and let it ideal, then turn the bike to right closely looking at the bike for sparks or any clicking etc...
Fastturbotalon is offline
post #15 of 15 Old 05-01-2012, 2:16 PM
could be a wire being pulled or pinched. Turn the bike when it's sitting in the driveway and see if anything is being pinched/pulled.
slothman is offline
HELP!!! Engine shuts off ... wait 10 minutes it goes again twvette Honda RC51 7 12-20-2010 11:12 AM
Starter spins but engine doesn’t turn over pgc351 Honda FireBlade 1 08-28-2007 2:42 PM
Bike just shuts off forceten Honda RC51 28 06-28-2007 8:17 PM
bike shuts off. WantaHonda Honda FireBlade 5 04-21-2004 6:13 AM
