CRF110 Carburetor Cleaning and adjustment - Honda Motorcycles - FireBlades.org
Honda Off-Road Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
 6Likes
  • 2 Post By IanDoohan
  • 2 Post By Jaybird180
post #1 of 12 Old 04-04-2018, 1:08 AM Thread Starter
Quoted: 254 Post(s)
Reputation Power: 10
I watched a couple YT videos the other night and decided that I could tackle cleaning my daughter's carburetor. First I had to get to the store to try and find a JIS screwdriver (or bit). I luckily may have found a suitable bit- I looks right and there are plenty in the little $8 kit to choose from, so I had a go at it.
I decided to take off all the bodywork to get better access. I know how to do it easier next time.
I drained all the fuel. It wasn't bad, I think I can reuse it. The air filter looks clean too. I should check the spark plug and motor oil (I'll do those tomorrow).
After removing the carb and cleaning the jets (some holes near the tip weren't passing light as I thought they should) I thought it wasn't so bad. I hope that soaking in carb cleaner was enough as I didn't have anything small enough to poke in the needle openings.
All was going well until it was time to put the float bowl back on and I noticed that the gasket seemed to have stretched a little.
Here's a pic of the gasket and the offending (?) chemical I used.
-My 06 Fireblade Build Thread
-Her 02 CBR600F4i Custom Suspension
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
-92 CB750 She lets me ride it, Jetted
-13 CRF110F, 01XR50 Daughter's
Jaybird180 is offline
post #2 of 12 Old 04-04-2018, 1:19 AM Thread Starter
Quoted: 254 Post(s)
Re: CRF110 Carburetor Cleaning and adjustment
Seems I need to get part number 16163-KWS-901
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #3 of 12 Old 04-04-2018, 2:47 AM
Quoted: 749 Post(s)
Reputation Power: 102
Pro tip when cleaning carbs in solvent.
Always remove o-rings and gaskets. O-rings are always a gamble whether or not theyíll swell from the chemicals. Sometimes the fuel/air screw will have an o-ring on it too.
And always have a spare rebuild kit on hand, easy when itís only a single cylinder.
WERA689 and Jaybird180 like this.
My Red Rocker 93 Build Link: Cafť 900RRP
IanDoohan is offline
post #4 of 12 Old 04-04-2018, 9:17 AM Thread Starter
Quoted: 254 Post(s)
Now he tells me. LoL
IanDoohan and chuckhunter like this.
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #5 of 12 Old 04-04-2018, 9:24 AM Thread Starter
Quoted: 254 Post(s)
The microfiche also reveals an o ring that I didn’t remove and it’s an expensive little booger. Should I also purchased that too and replace it anyway considering how the other appeared?
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #6 of 12 Old 04-04-2018, 11:28 AM Thread Starter
Quoted: 254 Post(s)
Also, there was an extra nipple and tube on this carb that I can’t identify. I’ve got fuel, air intake, mixture down tube and float bowl drain. What’s the other for? Appears to be for air but for what I don’t know (didn’t trace it last night).
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #7 of 12 Old 04-04-2018, 11:32 AM Thread Starter
Quoted: 254 Post(s)
Also, can I use a gasket maker instead of replacing the rubber gasket?
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #8 of 12 Old 04-04-2018, 12:44 PM Thread Starter
Quoted: 254 Post(s)
I talked with a trusted dirtbike mechanic who told me about a gasket in the freezer trick that can sometimes work. I'll give that a shot.
I sent him a link to this thread and he got excited when seeing the can of Gum Cutter and cautioned against using it in the future. He said he recommends Brake Kleen (I think that's a brand name) as it's gentler on parts that Gum Cutter. I'll probably toss the GC in the trash or return to the store if they'll take it back.
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #9 of 12 Old 04-04-2018, 3:58 PM
Quoted: 749 Post(s)
Next time you need give the board a heads up before diving into a Carbie project
The microfiche also reveals an o ring that I didnít remove and itís an expensive little booger. Should I also purchased that too and replace it anyway considering how the other appeared?
I would, but Iím the exception, not the rule
Also, there was an extra nipple and tube on this carb that I canít identify. Iíve got fuel, air intake, mixture down tube and float bowl drain. Whatís the other for? Appears to be for air but for what I donít know (didnít trace it last night).
Got a pic of it? Probably the float overflow drain.
I would say no. Are you talking like a liquid type stuff? Iíve never had to use a ďmakerĒ, but I have made gaskets out of sheet material for automotive applications. Iím a firm believer in using OEM stuff for motorcycle replacement, aspecially on carbs.
post #10 of 12 Old 04-04-2018, 6:51 PM Thread Starter
Quoted: 254 Post(s)
The "mystery" hose is a vent.
Today I called the local Honda dealer and inquired and they quoted a price of $32.xx for the full kit.
I think he was mistaken as I got it from their online store for $13.55. It will be shipped to the store and I'll pick it up...whenever.
Then I arrive home to try the freezer trick and notice that the gasket had shrunk noticeably in my cold garage and I was able to get the float bowl back on!
Should be smooth sailing from here!
I'll have to make a decision about using the same fuel vs tossing it out. BobVila.com indicates that the fuel is probably good and I hope so, I've got a few gallons of fuel spread out in 3 containers (2-stroke premix, 87 and 93 octane).
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #11 of 12 Old 04-06-2018, 4:38 PM Thread Starter
Quoted: 254 Post(s)
Happy to report that the bike is running great! I ran it with some "fresh" fuel and 3/4 of the old fuel, which had a slight yellow/brown tint because.....wait for it.....
I put Stabil in the tank (Doh!)
I was also able to solve the original problem which was a too fast idle. I simply needed to turn the idle adjustment screw. Leave it to me to find the complex reason when the answer is simple.
unslow1 and IanDoohan like this.
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #12 of 12 Old 04-06-2018, 8:20 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
unslow1 is offline
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Off-Road
Tuning Carburetor Jaybird180 General Discussion 2 02-16-2018 2:27 PM
Carburetor questions cbrmatt88 Kawasaki Motorcycles 10 11-15-2015 12:51 PM
carburetor leaking jeepstang1986 General Discussion 4 04-07-2012 4:09 PM
carburetor hondaxr100 Honda FireBlade 4 04-27-2011 12:18 AM
Help with cbr400 carburetor Douglas260 General Discussion 2 07-13-2010 1:34 AM
