What tool do I need? Oil Filler Cap - Honda Motorcycles - FireBlades.org
Honda Off-Road Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
 4Likes
  • 1 Post By Jaybird180
  • 1 Post By IanDoohan
  • 1 Post By BreakItBob
post #1 of 14 Old 04-04-2018, 1:33 AM Thread Starter
Quoted: 254 Post(s)
Reputation Power: 10
@IanDoohan ?
And where can it be found? I may have to make a trip to the local Honda dealer tomorrow (today?) anyhow. What do I ask them for?
And I can't find the dang-blasted thing on microfiche. [edit: found it! it's part number 15650-KYK-910 but it still doesn't tell me what tool I need to remove it.]
-My 06 Fireblade Build Thread
-Her 02 CBR600F4i Custom Suspension
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
-92 CB750 She lets me ride it, Jetted
-13 CRF110F, 01XR50 Daughter's
Jaybird180 is offline
post #2 of 14 Old 04-04-2018, 2:42 AM
Quoted: 749 Post(s)
Reputation Power: 102
Re: What tool do I need? Oil Filler Cap
That doesn’t look right at all Jay. Is that the 50 you have?
Haven’t seen one in a while, but they used to look like this. Did you cut that slot in it?
Looks like a job for the, and I hate to say it, vise grips. That doesn’t look OEM at all.
My Red Rocker 93 Build Link: Cafť 900RRP
IanDoohan is offline
post #3 of 14 Old 04-04-2018, 4:35 AM
Quoted: 42 Post(s)
as it's got a slot in it I would use a large flat blade screwdriver or thin flat bar to un-do it
machinehead is online now
post #4 of 14 Old 04-04-2018, 9:21 AM Thread Starter
Quoted: 254 Post(s)
This is the cap for the 110. If it’s not OE, then I presume the P.O. cut that slot.
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #5 of 14 Old 04-04-2018, 2:09 PM Thread Starter
Quoted: 254 Post(s)
The PO said he didn't cut the slot. A buddy who's had 5 110's at one time or another says the cap is OE and to use a flatblade to unscrew it. The slot seems wider than a flatblade to me. When I get it off, I'm replacing it with something more conventional. It's needs to be safety wired anyhow.
IanDoohan likes this.
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #6 of 14 Old 04-04-2018, 4:02 PM
Quoted: 749 Post(s)
Yup, you learned me something today Jay, it is in fact OEM. Iíve never seen something so odd. Get a replacement, that looks like too much work, just to get the dipstick out.
Jaybird180 likes this.
post #7 of 14 Old 04-05-2018, 4:41 PM Thread Starter
Quoted: 254 Post(s)
Swapping the filler cap/ dipstick is probably a no-go. The measurements for the 50 and 110 dipsticks aren't interchangeable.
Fortunately, the cap drilled quite easily to accept safety wire when I'm ready to do it.
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #8 of 14 Old 04-06-2018, 2:04 AM
Quoted: 749 Post(s)
Sorry if you thought thatís what I was suggesting. I was saying to just get an aftermarket one that resembled the 50ís, so itís easier to remove.
post #9 of 14 Old 04-06-2018, 10:37 AM Thread Starter
Quoted: 254 Post(s)
I know what you meant. I think it was just over tightened but once I removed it...The cap and dipstick is a single unit. Unless some aftermarket manufacturers makes one then I won’t be able to use the measure. Which reminds me: checking oil needs to be part of our after riding procedure, considering the oil is checked in a fully warmed engine (silly).
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #10 of 14 Old 04-08-2018, 3:03 PM
Quoted: 37 Post(s)
Reputation Power: 4
Attachment 87769
Would have bet a lot of money that his wasn't OEM! Still you're right, get a more OEM replacement
BreakItBob is offline
post #11 of 14 Old 04-12-2018, 10:03 AM
Quoted: 55 Post(s)
Is the slot designed to be able to use a coin to open it?
BenelliBlade is offline
post #12 of 14 Old 04-12-2018, 12:33 PM Thread Starter
Quoted: 254 Post(s)
Very likely that may have been the intent. Didnít even think of that. But who checks oil then pulls a coin from their pocket to do so? Who came up with this (not so) brilliant idea? How about a regular tool that would be expected when youíre holding a bottle of oil, like....a wrench (spanner).
post #13 of 14 Old 04-13-2018, 5:18 AM
Quoted: 749 Post(s)
What I donít get is where do you gain your twisting torque with that set up, why would Honda want you to use a tool to check your oil, and lastly, is the dip stick attached to the underside?
That makes even less sense, making it difficult to hold onto it while dipping and checking the level. Weird one for sure.
post #14 of 14 Old 04-13-2018, 9:31 AM Thread Starter
Quoted: 254 Post(s)
When I put a screwdriver in there it seemed to lock in place, the channel is deeper than it appears and the outer material is pretty stout. Iíd wondered if by twisting it was somehow relieving force by distorting the cap itself.
Yes, the dipstick is attached. Itís longer than the one for the 50 so the proper level can only be attained with it or similar length dipstick.
When checking level, the oil is supposed to be warm and the cap goes on just seated but not threaded.
I will need to get in the habit of checking level after a ride or session and watching for leaks during operation and just keep a mental monitor for excessive oil burning or blow by.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Off-Road
Oil filler cap jose_954rr Honda FireBlade 2 09-22-2017 9:09 AM
Oil Filler Cap missing 929 JAPbikes Wanted 2 03-27-2014 10:47 PM
Oil filler cap and clutch reservoir cap. GOT ANY? phantomx0_1 Honda FireBlade 6 10-24-2009 6:58 PM
Anti-tamper oil filler cap 900rrRider Honda FireBlade 8 03-20-2009 5:29 PM
Where to buy an allen key type oil filler cap? doron General Discussion 2 07-11-2007 2:04 PM
