Brembo CLUTCH MC & Galfer Braided CLUTCH Lines - Honda Motorcycles - FireBlades.org
Honda RC51 Discussion of the Honda RC51, Honda SP1, and Honda SP2 Motorcycles.
post #1 of 1 Old 01-08-2006, 2:40 AM Thread Starter
southpark460's Avatar
Reputation Power: 17
Send a message via AIM to southpark460 Send a message via Yahoo to southpark460
I installed my new Brembo 16x18 clutch master cylinder tonight. Fairly easy project. I didn't have nearly as many "challenges" with this project as I did with the brake side. All the banjos fit. Of course, I did have to machine a bracket the same as in this thread.
The Galfer line fit great. The lenght was dead on, and for once the connectors were pretty much oriented the proper direction! I removed the old clutch line and piping, and cut the rubber bushing off of the old assembly. I laid the new line in place and measured where the brackets from the old assembly were and safety wired the rubber bushings in those locations so that the brackets would secure the line along the bike. Tightened up the banjos and moved on to the reservoir mounting (which was the same as the thread above so I'll just skip that).
Bleeding was fairly easy too. Again, I started by bleeding the MC a bit to get the line wet. Then I did the standard bleeding at the bleeder on the slave cylinder. Within about 2 minutes, the line and MC were completely bled. The Brembo gives very good feeling to the clutch. Can't wait to give it a spin. I think 2 finger clutching should be very easy, especially with the Brembo shortys.
southpark460 is offline
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda RC51
Galfer lines with Brembo MC southpark460 Honda RC51 19 04-11-2009 11:03 PM
Brembo BRAKE MC & Galfer Superbike BRAKE Lines southpark460 Honda RC51 0 01-08-2006 2:28 AM
FS: Brembo 19x20 MC and SS lines - RC51 southpark460 For Sale 7 12-27-2005 11:02 PM
Galfer Superbike braided lines - DIY ?? replica General Discussion 3 07-19-2004 5:59 PM
Galfer Braided Stainless Brake Lines itsdesignateddave Honda FireBlade 4 07-09-2003 9:00 PM
