Windows help update and another question. - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 06-05-2004, 1:43 AM Thread Starter
NinerPilot's Avatar
Reputation Power: 25
Ok, in reference to this thread, I found a fix to (A) here .
I reinstalled Windows (Pro this time) and after running the first round of updates my USB ports were killed. I have a Wireless Mouse/keyboard combo, that the Keyboard runs off USB. When the computer boots and bios posts, the USB Keyboard works for bios, but once windows starts it kills (as in shuts all the lights off) my USB devices including my Logitech wireless keyboard, MS intelimouse explorer, and jump drive. None of them work. Any ideas why windows would kill all the USB ports?
Thanks,
Chris
NinerPilot is offline
post #2 of 9 Old 06-05-2004, 1:56 AM
Re: Windows help update and another question.
GET OUT OF THE HOUSE NOW!!!!!!!!!!!!!!!!!!
Oh and call a Priest too.
Hope this helps bro.
J
fumbducker is offline
post #3 of 9 Old 06-05-2004, 8:59 AM
Thanks,
Chris
when you reinstalled, did you do a full format, did it get rid of any bugs that were lingering? My neighbor just had this exact problem, so i reloaded w2k pro and it worked like a champ.
do you get an error of svchost file missing or image.dll missing?
bubba is offline
post #4 of 9 Old 06-05-2004, 6:41 PM Thread Starter
NinerPilot's Avatar
I dont get any errors, and I just instaled XP Pro over XP home using the "uprgade" option. Im about to the point to wipe it clean and start over..... again.
Chris
post #5 of 9 Old 06-06-2004, 9:17 AM
Chris
do it, it takes less time for a clean install as it would to trouble shoot it at this point
bubba is offline
post #6 of 9 Old 06-06-2004, 9:59 AM Thread Starter
NinerPilot's Avatar
Yeah, but backing up alllllll my sh!t is gonna be a pain. Oh well, maybe when I wake up.
Chris
post #7 of 9 Old 06-06-2004, 10:54 AM
Reputation Power: 19
Occasionally using the Windows Updates for the drivers can break it, sometimes hardware can be very similar but still need different drivers and Windows Updates isn't smart enough to deal with it. As a general rule I never apply the driver updates.
I can have a wild bash at some solutions for you to try but if you have no mouse or keyboard that will make it hard, so see if you can get hold of a standard PS2 mouse and keyboard for the moment.
1. Access the device manager and get into the properties of the USB driver, on the driver tab you should have an button to 'Roll Back Driver'. see if returning to the previous driver has any positive results.
2. Visit your Motherboard manufacturers website and download the latest drivers for the USB port on your motherboard try installing those
3.go into add remove programs and remove each of the updates in turn taking note of each ones number and testing the USB port (you *should* then eventually find the culprit) but don't forget to put the other updates back on.
matt232 is offline
post #8 of 9 Old 06-06-2004, 11:18 AM
Also, are your ports USB 2.0? If so you may need to disable usb legacy support in the cmos setup. You can also ditch the usb mouse because they have known problems with xp home/pro with functionality. You can get yourself a usb to ps2 adapter for like a dollar or two and plug it into your ps2 port.
Brian929RR is offline
post #9 of 9 Old 06-06-2004, 11:47 AM
Chris
you dont have 2 drives?
bubba is offline
