Window Tint Removal - Honda Motorcycles - FireBlades.org
post #1 of 32 Old 07-06-2003, 7:19 PM Thread Starter
Re: Window Tint Removal
My window tint is too dark for NC standards and I'd rather try to remove it altogether rather than take it someplace and spend the dosh to have it redone.
Has anyone ever removed window tinting and, if so, are there any tricks to this??
TIA!
Proofread carefully to see if you any words out.
Post-blade
BizJetGuy is offline
post #2 of 32 Old 07-06-2003, 7:21 PM
ND4SPD's Avatar
Reputation Power: 50
Go to Autozone, they have tint removal kits for like $15-$20 I think
ND4SPD is offline
post #3 of 32 Old 07-06-2003, 7:24 PM
Reputation Power: 24
I have heard it is easy to remove if you use steam, although never tried it myself.
ratter is offline
post #4 of 32 Old 07-06-2003, 7:28 PM
Single edged razor blade?
Bacchus is offline
post #5 of 32 Old 07-06-2003, 7:31 PM Thread Starter
Bacchus : Single edged razor blade? *
I was thinkin' that but I wanted to see if anyone had any words of wisdom before I started slashing the windows
Post-blade
post #6 of 32 Old 07-06-2003, 7:38 PM
ND4SPD's Avatar
BizJetGuy : Quote (Bacchus @ July 06 2003, 6:28pm)Single edged razor blade? *
That'll put scratches into the window and it'll take forever
ND4SPD is offline
post #7 of 32 Old 07-06-2003, 8:40 PM Thread Starter
ND4 - what's in the Autozone kit and what does it involve??
I'm wondering if I have to take the door panels off to get to every part of the tint on the front and rear side windows.
Post-blade
post #8 of 32 Old 07-06-2003, 8:42 PM
Skully's Avatar
Wal mart sells window tint remover also. I haven't used it but I think it's just a liquid you apply and leave for a few minutes then peel the stuff off.
A razor blade would be a bad thing for the rear window defroster too.
Craig
Skully is offline
post #9 of 32 Old 07-06-2003, 8:47 PM Thread Starter
Skully : A razor blade would be a bad thing for the rear window defroster too.
I was thinking that, too.
I'll check out the removal kits over the next few days.
Thanks!
ps: if I'm feeling motivated (and if anyone is interested), I may do a few before and after pics
Post-blade
post #10 of 32 Old 07-06-2003, 10:15 PM
Ive always used razor blades, but I only have done side windows ie no defrosters, etc.
G-Force Junkie is offline
post #11 of 32 Old 07-06-2003, 10:31 PM
Use the razor as your last resort. Especially if it was professional film. I've been there, done that, gotten the dirty looks from the neighbors.
I've never tried a removal kit but I would do that before trying to do it with a blade.
The steam idea sounds interesting.. not sure how it would work unless it simply softened the adhesive and make it easier to peel off.
What does the removal kit consist of?
- DH
Holeshot is offline
post #12 of 32 Old 07-06-2003, 10:36 PM Thread Starter
Holeshot - thanks for the input. Yep - it is professional film and I don't want to screw up the glass or defroster by using a razor.
I'd be real interested to hear some feedback from someone who has used one of the kits.
Post-blade
post #13 of 32 Old 07-06-2003, 11:33 PM
ND4SPD's Avatar
The removal kit is a solution that you spray/spread on the window tint, put the clear saran wrap stuff on it, let it sit, and it comes right off. Then you just gotta clean the glue
ND4SPD is offline
post #14 of 32 Old 07-07-2003, 12:32 AM
Never tried the remover kits,worked at a few auto dealers,side widows are easy.Start with one corner at the top,use a NEW razor blade to start,then peel pulling the tint down and keeping it as close to the glass as possible when pulling down.Clean the residue with a NEW razor blade and plenty of glass cleaner,I prefer invisible glass,the glass cleaner acts as a lubricant on the glass to keep the blade from scratching it.
jafo is offline
post #15 of 32 Old 07-07-2003, 12:34 AM
Take a sledgehammer to all your windows then call your insurance company.
ConqSoft is offline
window resizing for links stegen Off-Topic 4 10-27-2003 8:46 AM
Actuator removal? need help MarkN929RR Honda FireBlade 7 10-25-2003 1:13 AM
Shock and Fork removal BushrodW Honda FireBlade 9 07-17-2003 10:28 AM
