GM recall - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 11-04-2004, 4:49 PM Thread Starter
ND4SPD's Avatar
Reputation Power: 50
ND4SPD is offline
post #2 of 15 Old 11-04-2004, 5:20 PM
soon2b954's Avatar
Re: GM recall
What's new?
soon2b954 is offline
post #3 of 15 Old 11-04-2004, 7:39 PM
NinerPilot's Avatar
Reputation Power: 25
Re: GM recall
At least the Yukon Valdez is safe...
Chris
NinerPilot is offline
post #4 of 15 Old 11-04-2004, 8:12 PM
Re: GM recall
There's one out on massive numbers of late model Chevy pickups too.
The cables used to secure the tailgate in the down position are corroding underneath their vinyl coating leading to catastrophe when people are standing on them or loading/unloading equipment.
Grrr.
If I wasn't in such a strong position of equity on my '01 Silverado (I owe very little on it now), I'd trade the sumbitch off for a Titan or Accord or some other Japanese vehicle and never shop a POS American design again.
Chain is offline
post #5 of 15 Old 11-04-2004, 8:21 PM
soon2b954's Avatar
Re: GM recall
Grrr.
My father was an all American car man (he had a lot of problems with various cars over the years) we then convinced him to buy an Acura, he's never looked back since!!
post #6 of 15 Old 11-04-2004, 8:25 PM
Re: GM recall
I'm not at all surprised.
(Totally unrelated note: I said American design, not necessarily American built, for the record. They've been making Nissan pickups on assembly lines in Symrna, TN for years. What's un-American about that?)
Next time I go car shopping, I'm with your dad all the way soon2b!
Chain is offline
post #7 of 15 Old 11-04-2004, 8:32 PM
TAZ
TAZ's Avatar
Send a message via AIM to TAZ Send a message via MSN to TAZ
Re: GM recall
Have you ever seen a ten-year old Toyota? I never knew a car could rust so much in such a short period of time.
If you buy Japanese cars, fine - but no whining about the economy...
TAZ is offline
post #8 of 15 Old 11-04-2004, 8:38 PM
soon2b954's Avatar
Re: GM recall
Those days have come and gone!!
Here in Ontario we have major plants from GM, Ford, Chrysler, Honda and Toyota. So a portion of money goes back into our economy.
post #9 of 15 Old 11-04-2004, 9:55 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: GM recall
Chris
Not to worry...your ride is safe!
Red Rider is offline
post #10 of 15 Old 11-04-2004, 10:17 PM
Re: GM recall
Do Japanese cars not have recalls?
literbike is offline
post #11 of 15 Old 11-17-2004, 8:07 AM
Max
Re: GM recall
You guys have got to be kidding about the recalls. I really like my blade but take a look at the number of Honda car recalls and TSB's posted some time. I think the trans recalls on almost all late model Honda's cost about ten times what the total GM recalls did all by itself. Here is a quick example of one fairly new car for one year.
Bulletins for 2004 Honda Accord L4-2354cc 2.4L DOHC (i-VTEC) MFI
General Recalls
TSB Number Issue Date TSB Title 04-020 APR 04 Campaign - A/T Inspection/Replacement
Service Bulletins
TSB Number Issue Date TSB Title 04-026 MAY 04 Brakes - ABS Lamp ON/Intermittent DTC's Stored
04-023 MAY 04 Body - Right Side Trunk Trim Panel Hangs Down
04-024 MAY 04 Engine - Vibrates While Idling in Gear
03-091 APR 04 Exhaust/Interior - Sulfur Smell
88-023 MAR 04 Battery - Testing Procedure
02-002 MAR 04 M/T - Clutch Pedal Noise/Notchy Feel
04-012 FEB 04 Brakes - Pedal Hard to Press Upon first Application
04-009 FEB 04 Computers/Controls - HIM Module Updating
01-023 JAN 04 Engine Controls - Control Module Programming Procedure
03-082 DEC 03 Instruments - Troubleshooting Outside Temperature Gauge
03-062 SEP 03 Interior - Seat Belts Slow to Retract
02-064 SEP 03 Navigation System - Controls/Operation/Initialization
96-012 JUL 00 A/C - System Performance Testing
And here is a 2003 of the same model with more time to find problems.
Bulletins for 2003 Honda Accord V6-2997cc 3.0L SOHC CM6/CM8 (VTEC) MFI
General Recalls
TSB Number Issue Date TSB Title 03-041 JUL 03 Campaign - Multiplex Integrated Control Unit Replacement
03-029 JUN 03 Campaign - MICU Replacement
Service Bulletins
04-017 MAR 04 Interior - Seat Lumbar Support Inoperative
01-009 FEB 04 Engine - V6 Engine Oil Leaks
03-079 DEC 03 Fuel System - Long Crank Time/Hard Start
03-085 NOV 03 Body - Wind Noise From Upper Rear of Front Door Windows
03-069 OCT 03 Brakes - Front Brake Judder/Noise
03-070 OCT 03 A/T - Required PROM Update Following A/T Replacement
03-072 OCT 03 A/T, A/C, Cruise - Shift Indicator, A/C or Cruise Inop
03-071 SEP 03 Audio System - Audio Module Lens Comes Loose
03-058 SEP 03 Body - Creaking/Popping on Acceleration/Deceleration
03-036 SEP 03 Steering/Suspension - Vehicle Drifts To The Right
03-057 SEP 03 Body - Front Window Wind Noise
03-035 AUG 03 Body - Door Window Molding Wrinkled
03-037 JUL 03 Body - Roof Molding Channel Leaks Water To Interior
98-018 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
03-003 JUN 03 Body - Moonroof Won't Close Completely
02-067 JUN 03 Interior - Center Pocket Doesn't Work Properly
00-088 JUN 03 Brakes - Brake Disc Refinishing Guideline
03-022 MAY 03 Audio System - Remote Controls Malfunction
03-017 MAY 03 Audio System - CD Changer Won't Load/Play/Eject
03-027 MAY 03 Engine Controls - MIL ON/DTC PA200 (Air Fuel Ratio)
02-053 APR 03 Antitheft - Type 4 Immobilizer System Operation/Service
98-011 APR 03 Keyless Entry - Transmitter ID/Programming
03-020 MAR 03 Engine Controls/Emissions - OBD II DTC's & Monitors
03-019 MAR 03 Wipers/Washers - Wipers Streak/Smear the Windshield
03-018 MAR 03 Interior - Rear Shelf Rattles
02-069 NOV 02 Interior - Center Pocket Mat is Wavy
Max is offline
post #12 of 15 Old 11-17-2004, 11:55 AM
Re: GM recall
Max, where did you find that list of recalls?
Serial Thriller is offline
post #13 of 15 Old 11-17-2004, 12:15 PM
Re: GM recall
http://www.recalls.gov/
There is a difference between a recall and a service bulletin, by the way.
BDA116 is offline
post #14 of 15 Old 11-17-2004, 12:51 PM
Max
Re: GM recall
Your correct but if you look there are recalls on each of those listed. In five years my GMC truck has had a single recall for the tailgate strap (that I still haven't done) and other then that I have changed oil and rotated the tires. Runs like a bat out of hell and is still rock solid tight. My nephew works as a line tech for a Honda Dealer here in Plano and told me what a mess all the bad transmissions are right now.
If your looking for tsb's and recalls on a Honda I think alldata is a better place to start. The .gov site seems to either have a lot of bad or old information.
http://www.alldata.com/recall/make/Honda.html
Max is offline
post #15 of 15 Old 11-17-2004, 1:09 PM
sheepofblue's Avatar
Reputation Power: 48
Re: GM recall
GM transmissions rock. And i don't say this just because i did some s/w for them I went through a design class also and they are very well thought out compared to some others.
For example I went on a business trip and they cursed me with a Plymouth Neon (called it a midsize ) So I spent some time finding the false nuetrals in it
Must obey the sheep dog
sheepofblue is offline
2002 954 RECALL? Mangina Honda FireBlade 16 08-08-2013 6:17 PM
Heli-Bar Recall ConqSoft General Discussion 3 09-29-2004 9:12 PM
2004 1000RR4 Fireblade Recall jayB Honda FireBlade 13 08-19-2004 4:58 AM
2004 CBR1000RR recall allred Honda FireBlade 5 06-03-2004 3:45 PM
929 clutch recall Johnny Honda FireBlade 2 04-14-2004 1:51 PM
