spark plug help needed asap - Honda Motorcycles - FireBlades.org
post #1 of 19 Old 03-24-2005, 3:08 PM Thread Starter
so i am out cutting my grass and all is fine, about 3/4 the way through it sounds like it is missing. then it proceeds to sound like it is choking off because of no fuel. i add more fuel and the problem does not fix itself
i just pulled the plug and it is BLACK and smells of fuel.
is the plug the problem or a symptom of the problem? will replacing the plug fix the issue
bubba is offline
post #2 of 19 Old 03-24-2005, 3:10 PM
dB
Re: spark plug help needed asap
My guess is the float valve is stuck open by a piece of crud and it is flooding. The wet plug is a symptom.
dB is offline
post #3 of 19 Old 03-24-2005, 3:12 PM Thread Starter
oh yeah black smoke puts out of the exhaust too
bubba is offline
post #4 of 19 Old 03-24-2005, 3:12 PM Thread Starter
that would explain why it ran through the tank of gas like a V10
bubba is offline
post #5 of 19 Old 03-24-2005, 3:19 PM
dB
You might be able to just pull the bowl off and clean the valve/seat. If that doesn't work buy a new valve/seat.
This used to happen to me all the time on an old VW I had that had no fuel filter aside from a screen in the tank. I was too stubborn to put a decent fuel filter on it because the thing was pristinely stock...so I got used to pulling the bowl off by the side of the road.
edit: Oh yeah, while you're in there make sure there's no fuel inside the float (leak) and set the float height if you can find the spec.
dB is offline
post #6 of 19 Old 03-24-2005, 3:31 PM
Did you check the air filter??
Clicky here!
Newfie TLR is offline
post #7 of 19 Old 03-24-2005, 4:39 PM Thread Starter
Clicky here!
as soon i left the computer i went back to the mower and thought I would check the easy stuff
As soon as i found it i started thinking karma is a BITCH
you would not believe it - it had so much grass in it that it choked out the mower. i cleaned it out and she fired up with all 12 cylinders. but now the flywheel spring is ****ed up beyond repair.
bubba is offline
post #8 of 19 Old 03-24-2005, 4:55 PM Thread Starter
freakin part was 10.50 and shipping was 6. what a freakin rip off.
bubba is offline
post #9 of 19 Old 03-24-2005, 5:48 PM
Bubba, what is this, the third thread about mowing your lawn in a week?
luvtolean is offline
post #10 of 19 Old 03-24-2005, 5:51 PM
ND4SPD's Avatar
Reputation Power: 50
Mowing the lawn? Heck, at this rate I'll be shoveling snow next week
ND4SPD is offline
post #11 of 19 Old 03-24-2005, 8:41 PM
I'm with Z.
Screw the snow. Cripers, March 23rd and we had 3 inches!!!
post #12 of 19 Old 03-25-2005, 7:30 AM Thread Starter
nah man. i was gonna buy a new mower but was discouraged by the prices so i went and mowed with the old and then fouled a plug. so it only makes 2.
bubba is offline
post #13 of 19 Old 03-29-2005, 8:34 PM Thread Starter
so the part comes in today i get her all rev'd up and pull the rope she fires right up. i roll her about 20 yards and she dies. i can not get her to fire up again - has fuel, not flooded, has oil. the blade rotates and just not turning over.
i am freakin pissed at the lawn mower but the yeard needed to be cut, so i go and borrow my neighbors. i break the rope on his mother****in********inpeiceofshitnonlawnmowingwhor e is what my lawnmower is. now i am gonna have to buy another
bubba is offline
post #14 of 19 Old 03-29-2005, 8:41 PM
You forgot this one:
https://www.fireblades.org/forums/sho...=grass+bermuda
post #15 of 19 Old 03-30-2005, 4:54 PM
hire a gardener
CBR Riding Fool is offline
Spark plug code yulianusl Honda FireBlade 11 03-04-2005 8:03 PM
Spark Plug Questions timeBOMB Honda FireBlade 11 01-07-2005 6:09 PM
Your basic, simple spark plug change in a cage... Bacchus Off-Topic 16 06-21-2004 8:52 PM
Spark plug for 929... Ripfuel General Discussion 9 04-03-2004 1:34 AM
spark plug - heads up Seeker Honda FireBlade 7 08-18-2003 2:48 PM
