what is a throw out bearing - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 05-28-2005, 7:31 PM Thread Starter
stegen's Avatar
Reputation Power: 22
My dad was thinking that maybe it was the throw out bearing (in the thread about the station wagon a while back) but I dont know what it is or what it does. can someone inform me? I googled it and ask.com it and came up with nothing helpfull.
stegen is offline
post #2 of 12 Old 05-28-2005, 8:31 PM
Re: what is a throw out bearing
If you have a manual transmission vehicle.... the throw out is the bearing that is part of the clutch assembly.
Correct me if I am wrong, and I might be, it is between the clutch plate and the transmission itself.
Lover of all small woodland creatures.
DEPO is offline
post #3 of 12 Old 05-28-2005, 9:46 PM
First "hit" on throw-out bearing" on Google...
http://www.carcarecouncil.org/Manual..._bearing.shtml
Bacchus is offline
post #4 of 12 Old 05-28-2005, 10:58 PM
sheepofblue's Avatar
Reputation Power: 48
So either you didn't put one in last clutch change or someone has been riding with their foot on the clutch pedal
Must obey the sheep dog
sheepofblue is offline
post #5 of 12 Old 05-28-2005, 10:59 PM Thread Starter
stegen's Avatar
stegen is offline
post #6 of 12 Old 05-28-2005, 11:03 PM
Reputation Power: 17
Send a message via MSN to Cowboy1600
Its also called a spigot bearing.
Poking the Devil with a stick then running away
Cowboy1600 is offline
post #7 of 12 Old 05-28-2005, 11:25 PM
nedro's Avatar
Reputation Power: 27
If this is the thread you are refering to, it is not the throw out bearing. It is, as LTL stated, a broken or bent shifting fork. O.K., there are more things that could've happened. The shifter linkage could've come loose. Or the reverse shifter lever could've gotten jammed up in the reverse fork rod arm.
Ride Red
nedro is offline
post #8 of 12 Old 05-28-2005, 11:44 PM
I agree with Nedro. There are two modes of throw out bearing that come to mind. The first is that the bearing is noisy, this is the cheap one, do not drive the car until the bearing is changed and life is good. The second the bearing locks or seizes and usually burns of a clutch plate on the way out, replace the whole clutch including bearing (always replace the bearing when changing a clutch) Of course the bearing could also self destruct but I have not heard of this happening.
post #9 of 12 Old 05-28-2005, 11:52 PM
Originally Posted by stegen
I love you too!
Bacchus is offline
post #10 of 12 Old 05-28-2005, 11:54 PM
bjay51d's Avatar
shady tree mechanics said that to much sitting at the light with your foot on the clutch can mess up the bearing...
bjay51d is offline
post #11 of 12 Old 05-29-2005, 1:06 AM Thread Starter
stegen's Avatar
alright. you're probably correct. its in reverse but its in a neutral setting on the stick, you can move it left and right as if it was in neutral.
to the junk yard it goes!
stegen is offline
post #12 of 12 Old 05-29-2005, 3:29 PM
CBR929RE's Avatar
Reputation Power: 39
just use some damn muscle.
CBR929RE is offline
And we'll throw in a knife set.... Zeeman Off-Topic 3 02-28-2005 9:07 AM
Not bearing, F..up trans BAD SilverBullet Honda FireBlade 14 09-08-2004 9:11 PM
Front wheel bearing failure cbr929_son Honda FireBlade 6 07-20-2004 3:33 PM
Question about Steering Bearing SB Dookie Honda FireBlade 3 05-05-2004 2:56 PM
Wheel bearing replacement 425954guy Honda FireBlade 2 11-25-2003 10:39 AM
