Quick Excel Question - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 07-11-2005, 2:16 PM Thread Starter
tigerblade's Avatar
Reputation Power: 32
I need to reference a cell in a text string and can't remember how to do it. Example, I have a calculated value in cell C3 of "180" and I need to have a sentence elsewhere that says "180 payments". How do I get the cell value from C3 into the text string?
TIA
Is a paradigm worth 20 cents?
tigerblade is offline
post #2 of 14 Old 07-11-2005, 2:26 PM
dB
Re: Quick Excel Question
If I'm reading that right, use the CONCATENATE function. It's in the Text group.
edit: Example: =CONCATENATE(C3,"payments")
dB is offline
post #3 of 14 Old 07-11-2005, 2:42 PM
or
=C3& " payments"
RRWANTR is offline
post #4 of 14 Old 07-11-2005, 2:46 PM
Originally Posted by RRWANTR
or
=C3& " payments"
He'll go with the other one since it looks mo' smarter. He did that when I sent him a date formula last week (went with the more complicated one that he found somewhere else).
Pete is offline
post #5 of 14 Old 07-11-2005, 2:48 PM Thread Starter
tigerblade's Avatar
I think it's working. Thanks to everyone here not named Pete.
post #6 of 14 Old 07-11-2005, 2:51 PM
I guess he's not a fan of the KISS method.
RRWANTR is offline
post #7 of 14 Old 07-11-2005, 2:56 PM Thread Starter
tigerblade's Avatar
Nah, I'd rather dazzle 'em with formulas.
Both ways work. The CONCATENTATE fuction does seem to work nicely though since you can just tab from field to field and build your text. I'm sure they both have their merits.
post #8 of 14 Old 07-11-2005, 3:01 PM
dB
or
=C3& " payments"
dB is offline
post #9 of 14 Old 07-15-2005, 12:12 PM
phobiaphobe's Avatar
Reputation Power: 43
Ok I've got one... Anyone use DATEVALUE
I have 2 columns with dates; THe first column is the start date on a rental contract and the second column is today's date. edit: (or the closing date of the contract)
I want warnings when the contract is 70, 80, and 89 days old. I need a third column to have an "if" formula that gives me some sort of text as a warning.
I think I need to use a datevalue for the start date argued against a datevalue for todays date.
Any help would be much appreciated.
phobiaphobe is offline
post #10 of 14 Old 07-15-2005, 12:45 PM
dB
Check out the DAYS360 function.
Assuming start date is column A and end date is column B:
=IF((DAYS360(A1,B1))>70, "Over 70", "")
And the fully monty would be:
=IF(DAYS360(A1,B1)>70, IF(DAYS360(A1,B1)>80, IF(DAYS360(A1,B1)>89, "Over 89", "Over 80"), "Over 70"), "")
I'm sure RRWANTR or "PETE" will be here shortly to give you the 5 character solution.
dB is offline
post #11 of 14 Old 07-15-2005, 2:52 PM
HOly **** that worked perfectly. YOu're a ****ing wizard.
Thanks
post #12 of 14 Old 07-15-2005, 2:54 PM
dB
If the number of days is equal to or less than 70, the cell will be blank. You can put whatever you want between the empty quotes at the end of the formula to cover this condition.
Is it not working?
edit: Nevermind, I see you changed your post. Glad I could help. You may still be able to use the info above.
dB is offline
post #13 of 14 Old 07-15-2005, 2:56 PM
RRWANTR is offline
post #14 of 14 Old 07-15-2005, 2:59 PM
Is it not working?
FOr a "false" value I just put "OK". Works perfectly, thanks.
Need quick help...header install question???? tglass Honda FireBlade 3 05-23-2005 10:59 PM
Under Armor quick question, need an answer quick! deez Riding Gear / Luggage 14 07-15-2004 6:14 PM
Quick question about 1000rr exhaust DWC392 Honda FireBlade 5 06-11-2004 12:41 PM
quick brake question... Goose Honda FireBlade 7 05-25-2004 1:13 PM
Quick Question Maybe? juice Honda RC51 8 04-01-2004 9:10 AM
