edit: Evaporative Emissions Control System leak..should I care? - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 10-05-2005, 12:17 AM Thread Starter
SomeStrangeGuy's Avatar
Reputation Power: 34
As some of you may know the ex and myself aided some Winnebago'd Californians in practicing the P.I.T. maneuver with her parents' 2k4 Hyundai Sonata on our way to Az.
Well 2 months later she is getting a check engine light, she went to Autozone and had it read like a good girl and it came back with EGR system leak (large). I told her go to the dealership - they said the back left corner where we got the lovetap from the 28' Winnie a hose has come off and that is why the code is there.
Dealer cleared the code, told her to come back in a week. Light hasn't been back on.
My whole thing is - anyone know how critical this is on todays cars? It's one thing I have never really been familiar with, aside from ripping it off my CA model KLR650 over the winter. It was just a bunch of confusing plumbing to me though
Is this something that will show up on inspection time as horrid emissions, kill mileage, do damage to her engine or cat, or what exactly?
The only thing I can surmise is that since the left rear is where the damage is (very minor at that) and that is also where her gas filler is, there is now maybe some tensed line there that gave way...although the incident did not actually affect the material in/around the gas filler neck/door at all.
help
SomeStrangeGuy is offline
post #2 of 14 Old 10-05-2005, 12:21 AM Thread Starter
Re: edit: Evaporative Emissions Control System leak..should I care?
sidenote: I also think the dealer saw the left rear corner of the car, noticed it was a customer with breasts and said "uh yeah, problems definetely back there where the damage is"
She said they did poke around under the hood but <1 minute, and no one looked under the car that she could see. They did poke around in the trunk but 'couldn't see what they needed to' in the window of time they had.
funny, I had to repin some of the trunk lining because of the crash...now they don't have the time to remove it?
post #3 of 14 Old 10-05-2005, 2:10 AM
G-Force Junkie's Avatar
Reputation Power: 24
It is pretty much just for containing vapor emissions and such. I doubt it does anything to help/hurt performance, but I doubt you can remove it without a huge hassle. Not to mention it would not meet the visual inspection of a smog check or inspection if your state has those. A whole slew of sensors are hooked to that check engine light, you would not want to be running around with it on all the time because if a serious fault came up, you would never know. My 2K3 Tundra will set off the emissions idiot light if you turn the ignition with the gas cap off, so the idea that an impact tweaked a hose or seal on something is very likley. BTW, you can often reset the engine light yourself by disconnecting your battery for 10 minuts or so.
G-Force Junkie is offline
post #4 of 14 Old 10-05-2005, 2:22 AM
EGR system leak will fail emissions testing if your area has it. My EGR (aka secondary Injection pump for VW) valve threw a light. The system from what I understand is ONLY for emission control. With my car, the EGR valve pumps in air to dilute the exhaust fumes before expelling out the tailpipe. What's even more fustrating is that the system only kicks in during cold starts, and doesn't last for more than 5 minutes max (or was that 5 seconds....). Anyway, I'm still trying to find the root cause of why my light is on. Common problems are anything from leak in hose, the valve broken (and therefore cannot release the pressure), relay switch that triggers the mechanical parts to function, bad wires that's screwing up the relay switch, or the worst, air pump not working (rare).
Oh yeah, I HIGHLY doubt it's the damage from the rear.
Good luck.
Be fast or be last.
asiliat is offline
post #5 of 14 Old 10-05-2005, 8:20 AM
seamus's Avatar
Reputation Power: 31
You won't be able to pass an emissions test without the system working properly. It won't hurt performance but the light will definitely come back on. I don't know where the EGR system is on the Hyundai but I've never seen one that was attached to the exhaust system anywhere near the trunk.
seamus is offline
post #6 of 14 Old 10-06-2005, 11:07 AM
CBR Riding Fool's Avatar
Send a message via AIM to CBR Riding Fool
Good luck.
It has nothing to do with the EGR. EGR is a differant system. Its Secondary air injection system only. Not an EGR pump. Its only meant to run when cold during cold start enrichment to burn unburned fuel entering the exhaust. You may want to check the vacuum lines from the valve on the back of the cylinder head for it. They get hot and crack. You'll see where it comes from a soliniod that the ECM controls and then fron a vacumm source at the intake.
CBR Riding Fool is offline
post #7 of 14 Old 10-06-2005, 11:10 AM
For starters, Its not the EGR system your discribing. Its the Evap that has the leak if there looking near the back of the car around the filler neck. Its part of OBD2 emissions for check for pressure loss in the evap system to monitor leaks which can let fuel vapors aka hydrocarbons out into the air instead of being burn by the engine for cleaner emissions. If you post the actual code they gave you I can look it up and give you more info.
post #8 of 14 Old 10-06-2005, 11:18 AM
ND4SPD's Avatar
Reputation Power: 50
EGR adds fresh air to your exhaust to help the catalytic converters burn up any unburnt fuel that is passing through there...
ND4SPD is offline
post #9 of 14 Old 10-07-2005, 8:09 AM
bubba's Avatar
Reputation Power: 21
why do you care? she is your ex
"sorry I'm late, I had to stop by the wax museum and give the finger to FDR again" - Cotton Hill
bubba is offline
post #10 of 14 Old 10-07-2005, 9:29 PM Thread Starter
She told me the same thing when I sent you those goodies for the L back in the day
I think the Riding Fool has it - I remember talking to autozone chick third party and taking EGR from the conversation, but seem to remember looking up the error code for something different. I could be off, but I think the code was/or close to:
P0455 - Evaporative Emission Control System Leak Detected (gross leak/no flow)
I just remember it was large leak and evaporative that the code had and the above is the closest thing. They did reset the light and oddly it's back on as of today.
post #11 of 14 Old 10-07-2005, 9:30 PM Thread Starter
and btw thanks, I appreciate the assistance
post #12 of 14 Old 10-07-2005, 10:16 PM
thats the air injection. EGR adds burnt exhaust gases into yout intake to lower combustion chamber temps to lower NOX emissions.
post #13 of 14 Old 10-07-2005, 10:19 PM
Then need to inspect the evap sytem and look for a cracked, or loose hose, Sticking evap valve, even a loose gas cap can cause that.
post #14 of 14 Old 10-07-2005, 10:22 PM
ND4SPD's Avatar
Yeah yeah, I knew it was something like that
ND4SPD is offline
Edit: accidently posted thread twice thelemur For Sale 0 07-30-2005 11:39 AM
You too can reduce oxide emissions by peeing in your exhaust phobiaphobe Off-Topic 8 06-09-2005 4:00 PM
CA Emissions utherca Honda FireBlade 1 04-02-2004 9:40 PM
Edit Message Title Baketech General Discussion 2 05-26-2003 8:15 PM
