2006 Civic - Honda Motorcycles - FireBlades.org
post #1 of 43 Old 10-16-2005, 5:46 PM Thread Starter
SomeStrangeGuy's Avatar
Reputation Power: 34
2006 Civic
Took one for a drive today, just the high/low points tossed in here for good measure:
- new dash layout is awesome and gives the feel of much more space and provides viewable area in front of the car. The 'inline' appearance of it becomes almost holographic because the depth of field of two different gauge pods.
-engine hp upgrade is a nice plus, doesen't require nearly as much wringing now and almost has lowend (for a 4, its pretty nice). This is also much nicer because its quiet.
-suspension is a far cry from the Civics of old. Though still no double wishbone, the handling is tack sharp.
-4 wheel discs finally too, and they are silky and burly all at the same time = ask the dealer to take that protective plastic off the seats before you test drive it or you'll regret it
-Spacious interior! i never thought I'd say this about a Civic, but whatever kind of ergo engineering they did to it, getting in that and my Moms accord (coupe) is very similar. Before you could tell the difference, and you're still getting down lower - but the room is there inside the car. Also has a pretty big trunk and a backseat that I could ride to NJ in if I had to. Though I do not think your shocks would appreciate it.
-location of the shifter/ebrake is pretty cool now as well. No reaching involved and it felt like the 5spd had a really short throw. Unfortunately its still FWD so it has linkages and bushings that give a little rubbery feel, but the snickety-ness is still there.
-also has that 40mpg rating now too
-drivers side window has express upanddown, and the drivers side switch has knurls on it so you can ID it from the others with ease.
Downsides:
-engine bay is now smaller, doesen't look too too bad - but good luck reaching anywhere behind the block. The backside of the head is now inline with the edge of the bodywork /windshield..sorta like your favorite astrovan.
Though as usual everything else is pretty easy to get to and despite the weird crunch that occured, it is somewhat 'spacious' in and around the components, you at least have enough room to get your hands where they need to be for belts,fluids,filters and such.
-oval: some of the switches and junk are now oval...not all, just some - but they look weird to me.
-the trunk badging and the word civic look weird to me too.
-it doesn't have a bed like the ridgeline, so I cannot buy it.
On the plus side, ridgelines are invoice now, and there are some to-dealer incentives
SomeStrangeGuy is offline
post #2 of 43 Old 10-16-2005, 5:51 PM
Re: 2006 Civic
Good write-up SSG (registered trademark my azz... ) Until very recently I was planning to buy another 4WD (probably Toyota again) after I move. But with gas prices what they are, and being much higher there, I'm now thinking about the 40 MPG cars available. I have much research to do.
Bacchus is offline
post #3 of 43 Old 10-16-2005, 5:55 PM
stegen's Avatar
Reputation Power: 23
Re: 2006 Civic
I was considering a new civic till I heard that it was the Si that was 200 hp. I still wouldnt mind a civic but the wife (again) thinks they are ugly as hell.
Life is Good, Life is Great
stegen is offline
post #4 of 43 Old 10-16-2005, 6:04 PM
Re: 2006 Civic
Civics are great cars. Excellent MPG. But why can't the engineers put the dam oil filter in the front like the VW's & toyota's
oldgoat is offline
post #5 of 43 Old 10-16-2005, 6:16 PM
Re: 2006 Civic
oldgoat, although you're probably talking about sedans, I must say that my Tacoma oil filter is in a "special" spot. Have to go in through the left side front wheel well with a couple of ratchet extensions. Heaven forbid if you drop that puppy - lost down onto the skid plate - don't ask me how I know. OK SSG, your thread is yours again.
Bacchus is offline
post #6 of 43 Old 10-16-2005, 8:17 PM Thread Starter
Re: 2006 Civic
Oldgoat you'd be delighted to know that the Accords have the filter in an easily accesible spot, the civ it's just put on the block...but has always been nicely accessible from the drivers side of the car with the wheels turned to the right. I kinda thought it cool you didnt need to have a jack to do the change.
Baccy - on the new Tacomas its front and center (no joke) they actually used a remote mount filter and a nice little drain dealy so you can do a nearly dripless oil change.
On my CRF its a nice little plug on either side of the bike - no more junk on the bottom to snag on rocks or remove my skidplate for neither
Steg - The wife thinks a Civic is ugly but an STi is hot....until she sees the gas bill. She'd probably rather you get a H2 or something economical then
post #7 of 43 Old 10-16-2005, 10:52 PM
ND4SPD's Avatar
Reputation Power: 50
Re: 2006 Civic
I've seen a coupe and a sedan version so far. Only saw the rear of the sedan, and it was dark but it looked pretty good. The sedan was OK. Looked like a previous gen Acura CL(I think?) but IMO there's good potential for aftermarket body kits there
ND4SPD is offline
post #8 of 43 Old 10-16-2005, 11:02 PM Thread Starter
Re: 2006 Civic
Gotta say this is the first time H has produced a coupe I actually like better then the sedan (in stock or non-typeR trim). I almost bought a CL-s a few years ago till I realized a TL-s would be coming out.
But I ended up buying a Tacoma anyways
post #9 of 43 Old 10-16-2005, 11:47 PM
phobiaphobe's Avatar
Reputation Power: 43
Re: 2006 Civic
Cool car, I'd love to own one, but I'm still a little sad that Honda has gotten away from their traditional philosophies of what makes a great driver's car; Northern's 'Lude (though probably not as quick as this new SI) represents the pinnacle of those philosophies IMO.
phobiaphobe is offline
post #10 of 43 Old 10-18-2005, 9:31 PM
Re: 2006 Civic
A guy I work with just bought a new Civic 4door auto. Hes saving $100 a month by buying the Civic for his wife and parking her Nissan Armada. The Nissan was using that much gas.
Diesel954 is offline
post #11 of 43 Old 10-18-2005, 10:11 PM
Re: 2006 Civic
If Nissan's word holds true, they are going to sell an assload of these starting next year:
http://www.edmunds.com/future/2007/n...64/photos.html#
I may have to give in and buy a Nissan for a sporty efficient daily driver - pending final engine and mileage info.
BDA116 is offline
post #12 of 43 Old 10-18-2005, 10:31 PM
Re: 2006 Civic
I think that you are right Phobe...I love to drive my car, although it may not be the fastest around(ask anyone who has been in one) It handles very nice(soon to be better), although the ultimate drivers honda...Integra type R or S2000.
Those cars are a far cry from the "norm" that honda has fallen into as of late. When was the last time that honda stirred up the pot with a gotta have vehicle? ala nissan 350Z or even the latest fro that camp, the SKYLINE
Honda has been too long over due for this little makeover IMO, when you get dusted by a corolla in a civic you know that something needs to get changed
Northern RR is offline
post #13 of 43 Old 10-18-2005, 10:43 PM
ND4SPD's Avatar
Re: 2006 Civic
Looks like a Focus that got humped by a Quest. I like it
ND4SPD is offline
post #14 of 43 Old 10-20-2005, 10:06 AM
Re: 2006 Civic
The versa is not likely to sway many away from the scion tc, what with only 120 h.p. That ain't exactly exceptional for a 1.8 ltr., though torque figures may be somewhat competive with the tc.
SemperSquidly is offline
post #15 of 43 Old 10-20-2005, 10:13 AM
Re: 2006 Civic
Whoa! Daddy like!
HD
Heavy-Dee is offline
2006 Honda Civic Mo Noyz Off-Topic 49 09-14-2005 3:07 PM
good deal on civic? New954RRider Off-Topic 10 06-17-2005 1:23 AM
This civic duty crap is getting really old. CBRVFR Off-Topic 5 04-21-2004 6:03 AM
1987 Civic Ghetto Rice asiliat Off-Topic 4 09-23-2003 6:32 PM
Honda Civic on eBay 2.0 2OHOH2 Off-Topic 14 09-22-2003 10:37 PM
