Biodiesel - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 02-21-2006, 2:50 PM Thread Starter
smoothrideronli's Avatar
Biodiesel
What are your thoughts on biodiesel? How does it compare in your opinion to E85?
smoothrideronli is offline
post #2 of 6 Old 02-21-2006, 2:59 PM
ReaperAZ's Avatar
Reputation Power: 24
Send a message via AIM to ReaperAZ Send a message via MSN to ReaperAZ Send a message via Yahoo to ReaperAZ
Re: Biodiesel
Never heard of biodiesel.
Dan
ReaperAZ is offline
post #3 of 6 Old 02-21-2006, 3:11 PM Thread Starter
Re: Biodiesel
Check this link for more info.
http://www.biodiesel.org/resources/b...s/default.shtm
post #4 of 6 Old 02-21-2006, 3:44 PM
Re: Biodiesel
Is that the stuff made with cooking oil? A friend's dad has been using that in his Powerstroke for years. He goes around to restaurants in his area and they gladly give him their old oil, which he mixes/filters/does something with and uses it in his truck.
Serial Thriller is offline
post #5 of 6 Old 02-21-2006, 5:11 PM
Re: Biodiesel
Be carefull if your putting biodiesel in a PowerStroke. Ford does not recomend using any fuel with over 5 percent biodiesel. I know that it will work ("My mother's brother's uncle's dog walker uses it to run 12s in his F350, bla, bla, bla), but if you have any problems with the truck, ford may refuse to fix it under warranty.
ny954 is offline
post #6 of 6 Old 02-21-2006, 5:16 PM Thread Starter
Re: Biodiesel
The only problems that you should run into if you ise more than a 5% blend is a corrosion of the rubber fuel components. What consumers have on their side is that engine manufacturers make an engine to work with a fuel that meets an ASTM standard. If the biodiesel meets that standard they may be a valid warranty claim...but if you have any problems with your diesel using biodiesel it was probrably caused by something else.
