Re: Vonage Part Duex...
A friend of mine just got it and i helped him set it up. It isn't flawless.
The device they send you only supports two lines. If you need 3 lines, for example, they send you two of the devices. Nowhere in the instructions does it state that you can't hook up two of them without using a router. Why would i assume that it would? because they want you to connect your computers and router BEHIND the unit they sent. But due to an unavoidable IP confilct, won't work.
The instructions they send also don't mention that to install it behind a router you must forward ports 10000-20000 udp. Found that in the FAQ. I doubt it would have been a FAQ if it were in the instructions.
Yes, the tech support guy was not speaking what i consider to be english. No, he didn't have the knowledge to help anyway.
The device should support four lines. The lines are split between jacks (1 and 2), and that sucks for a two line phone.
Basically, the equipment they sent sucks, the support sucks, and the verdict on service isn't in yet. It's cheap, and it at least half-way works.
Considering that you don't even want a home line and the price.... try it.
Edit: the forwarding options and such are pretty cool.... You can make it ring your celly at the same time it rings your home among more.
