Help!! computer died - Honda Motorcycles - FireBlades.org
post #1 of 39 Old 05-07-2006, 2:47 PM Thread Starter
I was just web browsing on my computer and all of a sudden the thing just shut off. It won't restart. Press the power button and absolutely nothing happens. I cleared the CMOS. Nothing. The power led on the A8N-SLI premium is on. Any idea what's up? No burning smell, pulled one stick of ram, pulled power for dvd and dvd burner, pulled sata connector for hd, pulled and reconnected power to mb, and standoffs look good (screws there). Things been working fine for a few months.
A8N-SLI premium
XFX 7800GT
Seasonic S12-500
Athlon 64 X2 3800+
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
2x CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200)
RRWANTR is offline
post #2 of 39 Old 05-07-2006, 2:48 PM
ND4SPD's Avatar
Reputation Power: 50
Re: Help!! computer died
Power supply? CPU overheated?
ND4SPD is offline
post #3 of 39 Old 05-07-2006, 2:50 PM Thread Starter
Don't think the cpu overheated...it's been fine and I didn't get any warning beeps from the monitor i have running in the background. No smell from power supply....how would I test the PS besides plopping it in another computer. i'm thinking PS...but...
RRWANTR is offline
post #4 of 39 Old 05-07-2006, 2:52 PM
ND4SPD's Avatar
Originally Posted by RRWANTR
Don't think the cpu overheated...it's been fine. No smell from power supply....how would I test the PS besides plopping it in another computer
Stick your finger in it and turn it on.
Humor me and make sure the heatsink/fan are securely on the CPU and that there is no gap.
ND4SPD is offline
post #5 of 39 Old 05-07-2006, 2:54 PM Thread Starter
Heatsink is on securely as far as I can tell. (I keep an eye on the temps as I have the monitor displayed on the desktop at all times.
RRWANTR is offline
post #6 of 39 Old 05-07-2006, 2:58 PM
ND4SPD's Avatar
Not sure what to tell ya...double check all power connections all the way back to the wall and then try a different power supply.
ND4SPD is offline
post #7 of 39 Old 05-07-2006, 3:03 PM
Do you get anything when you power it up? Can you get to the BIOS setup? Any POST functions run? Any beeps coming from the MB speaker?
BDA116 is offline
post #8 of 39 Old 05-07-2006, 3:05 PM
Get a VOM and check the voltage on the input side then check the outputs of the PS. should be 110 going in and 12, 24 and possibly +/- 5VDC coming out.
Also, look around and see if there is fuse you missed. 9 out of 10 times it is a fuse.
Had one die at work, turned out it was the battery for the damn clock.
Damn engineers.
Mojave954 is offline
post #9 of 39 Old 05-07-2006, 3:06 PM
soon2b954's Avatar
I would guess power supply as well.
Look, lean, believe!!
soon2b954 is offline
post #10 of 39 Old 05-07-2006, 3:06 PM Thread Starter
Absolutely nothing. No bios, post, nothing. Only sign of anything is the power led on the motherboard itself (which is always on as long as the switch on the powersupply is on)
RRWANTR is offline
post #11 of 39 Old 05-07-2006, 3:08 PM
LED doesb't mean you are getting all your voltages?
Do you have the schematic for the MB or PS?
post #12 of 39 Old 05-07-2006, 3:09 PM Thread Starter
This doesn't have a fuse panel like your R1.. (or at least any I know of)
Damn engineers.
RRWANTR is offline
post #13 of 39 Old 05-07-2006, 3:10 PM
Then there are only two real possibilities: PS and MB. I'd give 99% that it's the PS. No matter how good they are, they are notorious for just giving up out of the blue. Better brands do it less often, but you can still get a bad one.
Break out the meter.
BDA116 is offline
post #14 of 39 Old 05-07-2006, 3:12 PM Thread Starter
Nope...don't see any.
RRWANTR is offline
post #15 of 39 Old 05-07-2006, 3:15 PM
true dat but there should be either a fuse or something between where your wall power comes and the PS. But, since you state you have an led lit, probblay good.
Still would call it the ps.
Computer help DUX Off-Topic 4 04-04-2006 7:01 PM
computer help Diesel954 Off-Topic 5 07-27-2005 4:32 PM
New Computer help Aychdot Off-Topic 15 03-29-2005 8:26 PM
Computer Question...help MacMan Off-Topic 5 02-07-2004 1:58 PM
COMPUTER HELP.. Jay Off-Topic 1 09-06-2003 1:22 AM
