Just so everyone is clear - Honda Motorcycles - FireBlades.org
post #1 of 29 Old 09-24-2003, 2:45 PM Thread Starter
Re: Just so everyone is clear
It is 'damper' not any of the following:
dampner
dampener
dampenerer
That is all.
HD
Heavy-Dee is offline
post #2 of 29 Old 09-24-2003, 2:51 PM
HondaGalToo's Avatar
Reputation Power: 31
HondaGalToo is offline
post #3 of 29 Old 09-24-2003, 2:54 PM
TEN
As in:
My girlfriend is 'damper' than yours??
TEN is offline
post #4 of 29 Old 09-24-2003, 3:01 PM
You are wrong. *
As a matter of fact, while technically correct, 'damper' drives me crazy. 'Dampener' actually describes what is happening, as in dampening chassis oscillations.
luvtolean is offline
post #5 of 29 Old 09-24-2003, 3:10 PM
luvtolean : You are wrong. *
Probably a short drive to get you there but let me help.
damper damper damper damper damper damper damper damper damper damper damper damper damper damper!
Could you define dampner for us?
thebackdraft is offline
post #6 of 29 Old 09-24-2003, 3:11 PM
You're both wrong. It's 'Steering Stabilizer'.
Alan is offline
post #7 of 29 Old 09-24-2003, 3:14 PM
Sorry, but I'm going to be that guy...
damp-er: A device that eliminates or progressively diminishes vibrations or oscillations, as of a magnetic needle.
damp-en-er: A device that deadens, restrains, or depresses.
Both are technically correct, but the industry term is 'damper'. *But who cares anyways, damper, dampener, potAto, potato, tomAto, tomato... Say it however you like.
Babbat is offline
post #8 of 29 Old 09-24-2003, 3:14 PM
I believe this is in the wrong forum!!! (busting HD's balls...)
ccwilli3 is offline
post #9 of 29 Old 09-24-2003, 3:26 PM Thread Starter
SUCKERS!!!!
post #10 of 29 Old 09-24-2003, 3:26 PM
Actually I read a book that specificlly stated it was damper not dampner or dampener. Just an fyi.
Of course Alan might have the best idea. Honda is calling their new gadget a steering stabilizer and doesn't scott's call theirs and steering stabilizer also?
post #11 of 29 Old 09-24-2003, 4:09 PM
tigerblade's Avatar
Reputation Power: 32
While we're at it:
you're = contraction of 'you are'
your = possessive
Is a paradigm worth 20 cents?
tigerblade is offline
post #12 of 29 Old 09-24-2003, 4:14 PM
So, what do you call those two things attached to your front wheel? Chassis stabilizers? How about the one attached to your swing arm? The same thing? Front and rear chassis stabilizers? Can't call them 'shock absorbers' because there is no such device. Maybe shock redistributor. Impact reduction device?
-Shrub
To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be.
WetShrub is offline
post #13 of 29 Old 09-24-2003, 4:25 PM
tigerblade : While we're at it:
your = possessive
If that the only thing you're going to say then your just nuts....
OntheEdge is offline
post #14 of 29 Old 09-24-2003, 5:03 PM
OntheEdge : Quote (tigerblade @ Sep. 24 2003, 12:09pm)While we're at it:
your = possessive
Do you mean, 'If that [is] the only thing you are going to say . . . .'
Motopilot is offline
post #15 of 29 Old 09-24-2003, 5:22 PM
WetShrub : So, what do you call those two things attached to your front wheel? *Chassis stabilizers? *How about the one attached to your swing arm? *The same thing? *Front and rear chassis stabilizers? *Can't call them 'shock absorbers' because there is no such device. *Maybe shock redistributor. *Impact reduction device? *
-Shrub
They are shock absorbers becuase they combine all of the bump absorption, both spring and dampening. *If it was just a shock or strut(no spring), damper or dampener would be correct, and the term you'd see in an engineering text on the subject. *
In my control systems classes in college the term was used interchangably, with dampener the most common usage by my professors. *Textbooks on the subject also use both terms.
TBD
I overstated a bit actually, I don't really care...
LP short stalk V's showmethebombs Off-Topic 10 07-18-2003 12:31 PM
