Not your daddy's electric car? 0-60 in 4 secs 100% electric.. - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 12-26-2007, 11:35 PM Thread Starter
Reputation Power: 37
How about this one for an all electric car? Tesla Motors
Attachment 27971
Attachment 27972
Attachment 27973
Attachment 27974
How It Works
When you build a car that's electric, you start with one built-in advantage: Electric cars just don't have to be as complex mechanically as the car you're probably driving now. Sophisticated electronics and software take the place of the pounds and pounds of machinery required to introduce a spark and ignite the fuel that powers an internal combustion engine.
For example, the typical four-cylinder engine of a conventional car comprises over a hundred moving parts. By comparison, the motor of the Tesla Roadster has just one: the rotor. So there's less weight to drive around and fewer parts that could break or wear down over time.
But the comparison doesn't end with the counting of moving parts. The engine and transmission of a conventional car also need lubricating oils, filters, coolant, clutches, spark plugs and wires, a PCV valve, oxygen sensors, a timing belt, a fan belt, a water pump and hoses, a catalytic converter, and a muffler — all items requiring service, and all items that aren't needed in an electric car.
The Tesla Roadster's elegantly designed powertrain consists of just the four main components discussed below. Mind you, these aren't "off-the-shelf" components, and each includes innovations, both small and large. But when you build a car from the ground up, you have the luxury of questioning every assumption — and to distill as you reinvent.
The Energy Storage System (ESS)
When we set out to build a high-performance electric car, the biggest challenge was obvious from the start: the battery. Its complexities are clear: it's heavy, expensive, and offers limited power and range. Yet it has one quality that eclipses these disadvantages and motivated us to keep working tirelessly: it's clean.
The Tesla Roadster's battery pack — the car's "fuel tank" — represents the biggest innovation in the Tesla Roadster and is one of the largest and most advanced battery packs in the world. We've combined basic proven lithium ion battery technology with our own unique battery pack design to provide multiple layers of safety. It's light, durable, recyclable, and it is capable of delivering enough power to accelerate the Tesla Roadster from 0 to 60 mph in under 4 seconds. Meanwhile, the battery stores enough energy for the vehicle to travel about 220 miles without recharging, something no other production electric vehicle in history can claim.
Motor
Some people find it hard to imagine our car's Lamborghini-beating acceleration comes from a motor about the size of a watermelon. And while most car engines have to be moved with winches or forklifts, ours weighs about 70 pounds — a strong person could carry it around in a backpack (although we don't recommend it). Compare that to the mass of machinery under the hood of $300,000 supercars that still can't accelerate as quickly as the Tesla Roadster.
But more important than the motor's size or weight is its efficency. Without proper efficiency, a motor will convert electrical energy into heat instead of rotational energy. So we designed our motor to have efficiencies of 85 to 95 percent; this way the precious stored energy of the battery pack ends up propelling you down the road instead of just heating up the trunk.
Transmission
Our transmission couples the fuel efficiency of a manual with the driving ease of an automatic. The Tesla Roadster has only two forward gears, allowing you to fine-tune your driving experience (but either gear will work for most driving scenarios). Unlike a manual transmission, the car will not stall if you have it in the wrong gear. There's also no clutch pedal. Just move the lever and the electronic control module takes care of the shift, so you can launch from a full stop to freeway speed without taking your focus off the road, your foot off the accelerator, or your hands off the wheel.
Power Electronics Module (PEM)
Most of the subsystems in the Tesla Roadster are completely electronic and under direct software control. But unlike all other cars, these systems are not a hodge-podge of independent systems — instead, they are designed as an integrated system, the way complex network and computer systems are designed today.
You'll see the hub of this network every time you pop the trunk — the Power Electronics Module. When you shift gears or accelerate in the Tesla Roadster, the PEM translates your commands into precisely timed voltages, telling the motor to respond with the proper speed and direction of rotation. The PEM also controls motor torque, charging, and regenerative braking, and it monitors things like the voltage delivered by the ESS, the speed of rotation of the motor, and the temperatures of the motor and power electronics.
The PEM controls over 200 kW of electrical power during peak acceleration — enough power to illuminate 2,000 incandescent light bulbs.
Maholli is offline
post #2 of 5 Old 12-27-2007, 12:29 AM
.OrgOwner's Avatar
Re: Not your daddy's electric car? 0-60 in 4 secs 100% electric..
Awesome! and it's just 98k I would own one for sure....
.OrgOwner is offline
post #3 of 5 Old 12-27-2007, 12:31 AM
Send a message via AIM to stoney0422
yea way to make anice electric car finally but way to make it so affordable after telling us electric cars dont have to be so mechanically complex!
if she is a Ferrari when you meet her, don't be surprised when you find out she is still a Ferrari!
stoney0422 is offline
post #4 of 5 Old 12-27-2007, 12:55 AM Thread Starter
Attachment 27975
I like the black the best...
Maholli is offline
post #5 of 5 Old 12-27-2007, 6:18 AM
These guys are bay area based aren't they? yea... would be nice to own one, but then again, If I could afford to buy one, I wouldn't have to worry about gas prices, therefore I would rather buy the new GTR
sammae01 is offline
Who killed the electric car .OrgOwner Off-Topic 35 12-20-2007 9:51 AM
Electric Help TomMac Honda CBR 600 1 09-09-2007 1:02 PM
finally, an electric car to get excited about Serial Thriller Off-Topic 20 08-30-2006 8:27 PM
man dies in homemade electric chair/ also drunk gets dwi in electric wheel chair... playinwitya Off-Topic 7 07-20-2006 11:56 AM
Don't wear your electric gear onto a plane... Baketech Off-Topic 2 01-07-2004 11:40 AM
