how to adjust cool down on furnace. - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 11-23-2008, 11:26 PM Thread Starter
stegen's Avatar
Reputation Power: 23
Hoping to avoid having to call a tech. When my furnace kicks on it runs fine then the burner turns off and goes into cool down to finish getting the heat out of the heat exchanger. When it does this it stays on way to long, it ends up blowing cold air which cools the room back down alittle.
Now i dont know off the top of my head what model i have (can get it if u need it to help) but how do you adjust how long the cool down time is? i guessing it probably just a pot you can adjust but does anyone have experience in doing this?
Life is Good, Life is Great
stegen is offline
post #2 of 3 Old 11-24-2008, 1:13 PM
Reputation Power: 17
Re: how to adjust cool down on furnace.
Sounds like it is some sort of thermal switch that is sticking. Do you see any wires or sensors hooked up tho the heat exchanger?
BigBassTurd is offline
post #3 of 3 Old 11-24-2008, 5:04 PM
nedro's Avatar
Reputation Power: 27
Yes,
a manufacturer;
a model #;
a serial #;
Year built is also nice, but may not be necessary at this point.
At least that way, we can figure out if you have an electronic control unit, or manual.
Ride Red
nedro is offline
How to adjust rear preload on 929 curt248 General Discussion 0 06-14-2008 7:18 PM
954 how to adjust for height? bobfluent Honda FireBlade 12 03-12-2008 7:22 PM
how to adjust a scotts damper? xxshawnxx Honda FireBlade 2 11-17-2005 1:10 AM
How to adjust needle clip position? goforitifudare Honda FireBlade 2 09-02-2004 11:29 PM
How to adjust ride height on Ohlins shock rydman Honda FireBlade 2 05-28-2003 2:08 AM
