Formatting a Novell protected Hard drive - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 12-20-2003, 2:21 AM Thread Starter
Send a message via AIM to Aychdot Send a message via Yahoo to Aychdot
My buddy just bought a used laptop and wants to start from a basic windows 98 setup. Problem is that Novell (I believe) will not let him do a Format C: Any Ideas thanks.
Aychdot is offline
post #2 of 5 Old 12-20-2003, 10:14 AM
Re: Formatting a Novell protected Hard drive
you need a startup disk thas has the stuff to erace/create a new partition and format. supress partition, create partition,format partition fat32, make it the bootable partition, install win98.
If I am correct, some win98 cd's are bootable and will do the stuf mentioned above
forgot to mention the command you need to partition is fdisk.
Keep the rubber side down!
DanDRRMan is offline
post #3 of 5 Old 12-20-2003, 12:19 PM
Create a Windows 98 startup floppy by going to Start/Settings/Control Panel/Add Remove Programs. The third tab is used to create the startup disk.
Boot from the floppy, it will copy all of the utilities to a RAMdisk, C: if the HDD if not FAT.
Fdisk is the utility you use to remove any partions currently on the drive and create a new one. Reboot and format the new partition before installing Win 98.
You should also run Fdisk /MBR to remove the old Master Boot Record before putting Win 98 on it.
Hope that helps.
Keith
Keith_929 is offline
post #4 of 5 Old 12-24-2003, 12:51 PM Thread Starter
It took a couple of days, but with you guys help, this not too computer savvy guy got it back up and running. Thank you very much.
Aychdot is offline
post #5 of 5 Old 12-24-2003, 3:36 PM
thanks guys, i will keep that one for the kit bag
bubba is offline
