homeowner question - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 01-20-2004, 3:51 PM Thread Starter
homeowner question
I have an older house with a crawl space. I know its common to have older houses need extra support for the floors. My bathtub seems to be falling because the grout line around the tub keeps cracking. Now there is a significant gap between the relatively new grout and the bottom of the tiles. There is also a spot in the main walkway where the walls are cracking and the floor seems to be weaker. Anyone have experience or advice about how to proceede with repairs?
Thanks,
B
pushbike4 is offline
post #2 of 11 Old 01-20-2004, 4:21 PM
nedro's Avatar
Reputation Power: 27
Re: homeowner question
You'll need 4x6s, 2x6s, plywood (same size as existing), and joist hangers. Plan on removing the tub since you say that the tub keeps sinking. You'll probably need some bottle jacks to hold up the subfloor while making repairs. You won't need the crawl space since you'll be pulling up the subfloor to make repairs to the damaged area. Before closing it back up, make sure to apply copper green to everything you can reach (beems, girders, plywood).
YOU WILL BE OPENING UP A CAN OF WORMS! So be prepaired. Good luck.
Ride Red
nedro is offline
post #3 of 11 Old 01-20-2004, 4:35 PM
Have you gone under the house to see if you have a pillar or two under that area that are sinking? If that is the case, releveling may be in order, and maybe you can save yourself the expense and hassle of replacing floor joists and subfloors.
Pete is offline
post #4 of 11 Old 01-20-2004, 4:40 PM
Thanks,
B
Are you on a peer&beam or a slab? What type of soil do you have, (Clay/Sandy Loam/etc)?
figment is offline
post #5 of 11 Old 01-20-2004, 4:42 PM
Doesn't a "crawl space" indicate that the house is off the ground? That's what I was thinking, but I'm not too keen on them Yankee terms.
Pete is offline
post #6 of 11 Old 01-20-2004, 4:57 PM
Damn Southerners
deez is offline
post #7 of 11 Old 01-20-2004, 5:54 PM Thread Starter
The house is definatly not on a slab i.e. I can crawl under the house and place bottle jacks etc. I'm not sure the floor is rotten under the tub, I really think its a support issue since i'm seeing it in other places (of course that does not rule out additional problems). We are blessed with a nice clay soil here in north Alabama, so once its supported I don't expect too much movement.
post #8 of 11 Old 01-20-2004, 6:02 PM
nedro's Avatar
I've never really heard "Nice" and "Clay Soil" in the same sentence before. Go figure. I suppose you've never had to dig trenches in clay soil before.
Ride Red
nedro is offline
post #9 of 11 Old 01-20-2004, 6:49 PM
No, a crawlspace can be anywhere, like in the eves of some older homes.
figment is offline
post #10 of 11 Old 01-20-2004, 6:50 PM Thread Starter
I was being facetious
post #11 of 11 Old 01-20-2004, 6:53 PM
Since you are not on a slab, you may be less effected by soil movement. Clay has a bad way of expanding and contracting unless kept at a fairly constant moisture level. Id have an Engineer come out and measure your house for movement.
figment is offline
Grattan Raceway Question Newfie TLR Track Days / Riding Schools 2 01-19-2004 8:24 PM
Ohlins question fivestar Honda RC51 8 01-08-2004 4:26 PM
Question for IT guys (Source Control Question) Pulse Off-Topic 7 12-19-2003 8:49 AM
amperage question BushrodW Honda FireBlade 8 09-24-2003 3:38 AM
