ahlmans formula - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 02-18-2004, 12:58 AM Thread Starter
ahlmans formula
ok, this is really driving me crazy. I got the ahlman's speedo recalibrator and I want to figure out what my mph should be. I am using the formula on this page http://www.jahlmandesign.com/instructions.htm but no matter what numbers I use for gear ratio it doesn't come out to a number that makes sense. Someone else give it a try for me please.
These are the numbers I have from the 954 service manual.
Primary reduction 1.52 (73/48)
Gear Ration (6th) 1.19 (25/21)
Final Drive Ratio 2.69 (43/16)
Rear Tire Circ. 24" (rough guess)
with these numbers, and rpm at 3,000 the formula says speed would be 168mph?
Please some smart math guy check this out. Am I being retarded or is this formula really screwed up??
Thanks!
MedTechRR is offline
post #2 of 16 Old 02-18-2004, 2:06 AM
Re: ahlmans formula
Just borrow a GPS, find the speed difference, and calculate the percentage. Much easier that way.
ConqSoft is offline
post #3 of 16 Old 02-18-2004, 9:14 AM Thread Starter
Re: ahlmans formula
I know it'd be easier to do that, or to find one of those MPH radar signs but it's driving me crazy why this stupid formula isn't working for crap. I'm going to have to give up and blame it on the formula!
post #4 of 16 Old 02-18-2004, 9:23 AM
cbr99xx's Avatar
Quoted: 27 Post(s)
Reputation Power: 27
Re: ahlmans formula
Thanks!
You might want to check your rear tire circumference... if the formula requires circumfrence rather than diameter your number is way off.
Life always looks better through bugs on a face shield.
cbr99xx is offline
post #5 of 16 Old 02-18-2004, 11:56 AM
dB
Re: ahlmans formula
Bingo. The formula uses circumference, not diameter.
dB is offline
post #6 of 16 Old 02-18-2004, 2:08 PM
Re: ahlmans formula
which would cut that by a little over a 3rd and put you around 55mph.
Oops! Guess I should look at the formula first. I assumed we were using the rear tire circumferance in division not multiplication. Nevermind.
sweetonion is offline
post #7 of 16 Old 02-18-2004, 2:24 PM Thread Starter
Re: ahlmans formula
ok, I checked the actual circumference, which is 78". The only problem is the way the formula is stated, this makes the mph 546?? The formula is obviously wrong, or my head is? It still doesn't make any sense, in fact it's getting worse?
post #8 of 16 Old 02-18-2004, 2:32 PM
Re: ahlmans formula
78” is the perimeter of the wheel and not the circumference. If that was true you would have a wheel that was 78” x2= 156”… I would hate to see the tire for that. The Circumference is half of the diameter of the wheel… If you have a 17” wheel then you have an 8.5 Circumference.
That might help you with the math.
ranger31 is offline
post #9 of 16 Old 02-18-2004, 2:35 PM Thread Starter
Re: ahlmans formula
umm, circumference is the length around the outside of the tire, or how far the tire will travel in one rotation.
I think the denominator of the equation they give should be 880, this makes the numbers all make sense. I'm guessing that was their error. Now I can sleep at night!
post #10 of 16 Old 02-18-2004, 2:48 PM
dB
Re: ahlmans formula
Ok...I tried the math for myself and you're right, it doesn't work. I suspect the problem is the "88" in the denominator (not sure where that came from?).
The top of the equation seems to work. I'll use 5000rpm because I know that means about 75mph on my bike. Also, you have the ratios calculated backwards in your first post...
Primary reduction 48/73 = .657
6th gear 21/25 = .84
Final drive 16/43 = .372
Circumference = 78"
so: 5000rpm x .657 x .84 x .372 x 78in = 80,067inches/minute
There are 63,360inches in a mile, so: 80,067/63,360 = 1.26miles/minute
Multiply by 60 to convert to hours= 75.6miles/hour Which seems right.
I'm sure the 88 is a factor to do the inches-miles and minutes-hours conversion, but I think it is wrong.
edit: By my math, the correct denominator should be 1056
1 / ((60min/hr) / (63360in/mile))
dB is offline
post #11 of 16 Old 02-18-2004, 3:07 PM
Re: ahlmans formula
Diameter
The diameter of a circle is the distance across the circle, through it's center. It is the circle's width and is usually represented by the letter d. It is twice the circle's radius.
Radius
The radius of a circle is the distance from it's center to it's edge:
It is half of the circle's diameter
Circumference
The circumference of a circle is the distance around the circle. It is the circle's perimeter.
ConqSoft is offline
post #12 of 16 Old 02-18-2004, 3:13 PM Thread Starter
Re: ahlmans formula
I know the ratio's I posted are backwards but this is the way the service manual listed them. When I entered them into the formula I swapped them around so they were correct. Well, now I can sleep easy because I know it's the formula and not me.
post #13 of 16 Old 02-18-2004, 3:30 PM
Re: ahlmans formula
Just go find a radar 'sign', or use mile markers, worked for me.
slowpoke is offline
post #14 of 16 Old 02-18-2004, 4:06 PM Thread Starter
Re: ahlmans formula
well, that would be the easy way out. I coudn't just give up. Plus, now I have a fancy excel spreadsheet that others can use to easily determine what their speedometer should read and also what affects changing gearing will do on speeds. Just enter your rpm, countershaft sprocket, rear sprocket, and tire circumference. Stock info is entered. Maybe this is good enough to stick in the KB or something
Anyway, hope it helps someone else!
post #15 of 16 Old 02-18-2004, 4:12 PM
dB
Re: ahlmans formula
Sweet!
dB is offline
Rob Tuluie: Renault Formula One tigerblade Road Racing: Club / Amateur 1 01-08-2004 1:04 PM
USGP - Formula 1 BizJetGuy Off-Topic 12 09-26-2003 9:54 PM
Formula Racing School grafixman Off-Topic 4 06-23-2003 5:45 PM
Ahlmans Speedo corrector larddog954 Riding Gear / Luggage 4 06-12-2003 1:28 AM
Ahlmans Speedo corrector larddog954 Honda FireBlade 0 06-11-2003 7:18 PM
