-   -   For all you reg/rec experts... (https://www.fireblades.org/forums/honda-fireblade/105709-for-all-you-reg-rec-experts.html)
vfrman 09-03-2013 11:38 PM
Ok,
So I was on a Superhawk forum and there I found a list of regulator/rectifiers that are compatible to the Superhawk. I figured if it would work for one Honda, it would work for another.... :pray:
So I bought a unit from a 2007 Ninja ZX-6R. Apparently this unit is MOSFET and is "cut and splice" to the Superhawk. Perfect, I think. :think:
The unit came in the mail today, and there is an extra wire!!! Oh ****. :fear: So, I download a wiring diagram and trace the wire to the signal side of the headlight relay...you know, the side that sends the current through the coil to close the relay and supply. I traced this wire back further to the 30A main fuse. Looking at the wiring diagram, it LOOKS like this extra black wire (which is at least half the size of the rest of the wires) ties in directly to one of the alternator outputs BEFORE it goes into the R/R! WTF?
Check out the diagram and the pics...
http://farm8.staticflickr.com/7404/9...5067bab2_o.jpg
The white wire (bk/bl on the R/R) goes directly to the 30A main fuse to the battery, the fuse block, and the ignition switch. The black/yellow (bk/w) goes to ground. My question is what do I do with the green (bk on r/r) wire? Do I wire this into a relay? do I ignore it? You can see in the pics of the r/r that all the wires go into the R/R....
Do MOSFET R/Rs have a signal from the ignition to turn on?
http://farm4.staticflickr.com/3752/9...b2f76dc1_b.jpg
http://farm6.staticflickr.com/5477/9...84cf399a_b.jpg
http://farm4.staticflickr.com/3694/9...f64a2db0_b.jpg
http://farm8.staticflickr.com/7380/9...56d633c3_b.jpg
900rrHonda 09-04-2013 12:55 AM
Re: For all you reg/rec experts...
Err I dunno what kawi had going with that? I could only guess.
But for use on a honda should work. Just delete that connection from stator wire to harness you said kawi used for headlight and stuff . Honda doesnt run that way, all power runs thru r/r then to main fuse, Then else where.
No a mosfet don't have. On off signal wire or anything. Well mine didn't I installed.
Keep us updated on your install
bladeracer 09-04-2013 4:23 AM
Originally Posted by vfrman (Post 1138864)
Ok,
Maybe ask on that forum if they're the ones assuring you it will work?
Does the bike run any AC components?
It says ZX6 rather than ZX6R on the regulator - maybe it's a ZZR unit?
What is that wiring diagram from? I don't recall ever seeing one with that wiring setup.
Honda would be a green ground.
vfrman 09-04-2013 9:33 AM
The diagram is for the 07 ZX6R. I saw on another forum that the wire is a signal wire for the headlights to come on after the bike is running, which makes sense if it is branched off the alternator wire...but the A/C current doesn't jive with the rest of the system.
bladeracer 09-04-2013 9:45 AM
In that case the AC voltage probably passes through a diode before reaching any of the electrical components?
900rrHonda 09-04-2013 10:04 AM
So don't even worry about trying to hook that wire that way it is just run. The thee power from stator to reg and power ground from reg to battery fuse.
dunno what kawi was smoking with the power used straight from stator that's a/c power vs needing the d/c power. But blade is prob right may have. Diode of some sort to swap it over
bladeracer 09-04-2013 10:27 AM
It looks similar to how cars are usually wired, they also take the signal directly from the stator.
Yep, I definately would not connect that third stator wire to the bike, just leave it running into the rectifier.
vfrman 09-05-2013 1:06 AM
Cool. I'll hook it all up tomorrow and see if the bike catches fire....LOL!
Here is the headlight relay from the wiring diagram. The wire from the reg/rec is the green wire here...
http://farm8.staticflickr.com/7366/9...e6926018_o.jpg
So, blade once again you are right...the current hits a diode before going into the relay...
900rrHonda 09-05-2013 4:26 AM
But isn't that for the kawi? And its going on the honda? So holds no relevance other than kawi is weird lol
Good to know for future reference tho, I didn't know they did that.
Let us no how the install goes. Should be easy. No fires should happen lol atleast I would hope not
vfrman 09-05-2013 9:15 AM
Exactly. That 6th wire is to turn on the headlights on the Kawi. So I'll just ignore it.
vfrman 09-07-2013 9:46 PM
OK. Got it all installed today...and after blowing the main fuse, all is good. FYI, blk/white is ground and blk/blue is +ve...oops.
So, here we go...Ideally I would like a better mounting place, but I'm thinking of making some vents in the track plastic allow some air in.
http://farm3.staticflickr.com/2884/9...6f5d94cd_b.jpg
http://farm4.staticflickr.com/3796/9...98f616cf_b.jpg
http://farm4.staticflickr.com/3771/9...185ec55c_b.jpg
http://farm6.staticflickr.com/5490/9...9d083636_b.jpg
http://farm6.staticflickr.com/5503/9...3f7e57db_b.jpg
http://farm3.staticflickr.com/2891/9...0047dd1e_b.jpg
http://farm4.staticflickr.com/3763/9...24ff2078_b.jpg
And with the tail on...
http://farm3.staticflickr.com/2858/9...ec2230bd_b.jpg
http://farm8.staticflickr.com/7437/9...4c9213e8_b.jpg
And here is the TINY stock unit in the stock location...
http://farm6.staticflickr.com/5544/9...b36ec070_b.jpg
900rrHonda 09-08-2013 2:32 AM
So have you tested it and get good volt numbers.
See its on a track bike. Lets us know how it holds up to the conditions
vfrman 09-23-2013 1:17 AM
I tested the reg/rec today. 14.76 volts at idle and 14.83 at 5k rpm. I'm calling that a win.
900rrHonda 09-23-2013 1:30 AM
Seems like the reg is already working hard to keep volt down even at idle. Since its already 14+ volts idleing.
Hope she holds up for ya! :-)
Keep us updated.
bladeracer 09-23-2013 1:36 AM
Keep us updated.
That's what it should be making, the battery still needs charging at idle.
Copyright © 2016 FireBlades.org. All Rights Reserved.
