-   -   03 CBR 954 Problem with key-ACC ON [HELP] (https://www.fireblades.org/forums/honda-fireblade/106944-03-cbr-954-problem-key-acc-help.html)
wiextreme 01-29-2014 1:50 PM
Please Help me anyone...
I have problem with my 954 turn on key acc problem..
when i put the key and turn it to ON position, the gauce (speedometer) light and number does not coming out.. but the HISS led are normal..
I have check all of the fuse are normal (inside front seat)
before i got these problem the bike is normal.
I have post the video on these link:
thank to everyone whos share your experience. many thanks.. :)
wiextreme 01-29-2014 1:55 PM
Re: 03 CBR 954 Problem with key-ACC ON [HELP]
is that posible with my ECM ?
can i replace any used ECM on ebay to fit with it?
thx..
bladeracer 01-29-2014 4:16 PM
Honda cbr 954 turn on acc problem - YouTube
But it starts and runs fine?
bladeracer 01-29-2014 4:17 PM
thx..
You would need a HISS ECU with it's matching key.
wiextreme 01-29-2014 11:39 PM
the bike is no have any problem before.. so weird.. i really confuse with that problem..
i turn the key on and off repeatly i got no light show-up on speedometer
wiextreme 01-29-2014 11:43 PM
but I do not need to replace a set of new keys with his ECM?
bladeracer 01-29-2014 11:46 PM
I mean it runs fine now - your only problem is the lights don't work?
bladeracer 01-29-2014 11:47 PM
It's up to you whether you replace the keys but I wouldn't bother.
All you need is the chipped key that is coded to the ECU you buy. If you keep it on your key ring then it will trigger the HISS and allow you to use your existing keys.
wiextreme 01-30-2014 12:01 AM
i cant even to start my bike because when the key i turn to ON position, i got no sign (light,neutral light,odo digital number,etc) to light up..
is it posible wrong with my ECM?
oh ic. is mean posible i can bought only the ECM on ebay.. ic.. thx for the information..
bladeracer 01-30-2014 3:01 AM
Does the fuel pump prime when you turn on the ignition?
Is the battery charged up?
Have you tried jumper cables to a car battery?
wiextreme 01-30-2014 3:12 AM
fuel pump does not prime, just because it was no electrical going on after i turn key to ACC-ON position... so strange..
here i just upload video:
bladeracer 01-30-2014 3:16 AM
No power ON key ACC CBR954 - YouTube
There is power to the HISS light and sensor though?
Unfortunately I can't think of anything other than a broken wire or connector in the harness perhaps, or maybe the base of the ignition switch.
wiextreme 01-30-2014 3:27 AM
yes, the HISS light is goin ON normally..
im just replace the new battery yuasa 12v 9ampere and nothing good..
wiextreme 01-30-2014 6:22 AM
Problem Solved!... wired cut-off cause by wreak harness itself.. thanks in advance sir Bladeracer..
dazodiac 02-02-2014 8:30 PM
BladeRacer's a boss lol
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
