-   -   Several codes, not running (https://www.fireblades.org/forums/honda-fireblade/128049-several-codes-not-running.html)
MrPickwick 05-16-2018 2:56 AM
Re: Several codes, not running
1 Attachment(s)
Just before you put everything back, , ignition on and turn the engine over at wide open throttle for about 10 seconds, should clear the cylinders , if your sure your getting fuel to the cylinders attach everything and see if it starts, if not try the starter fluid spray (just a mist), then check again for fault codes, just in case (and I know it should be right) check the right plug is going to the right cylinder, I know the harness should be in that order but I'm belt and braces
BigdaddyPaz 05-17-2018 1:08 AM
Originally Posted by gjp03954rr (Post 1699337313)
What i thought too even with timing off should sputter. Yes checked firing by hanging plug out, grounded to frame. Still have harness out, any other thoughts before i put it in wire loom and put back in place?
Check the gray connector towards the front of the bike that connects to the cluster, i had a melted wire in there that was hard to see. but the plastic gave it away.
gjp03954rr 06-29-2018 12:00 AM
FINALLY had time to work on bike. Got everything back together after doing the suggestions and still wont start but all codes are cleared except 7,9, and 34 which arent hooked up because air box is off and egcv is out. I sprayed starting fluid and it now sputters with quite a bit of it sprayed in it. Ended up pulling injectors out and they arent spraying fuel. I thought it was getting fuel because i had checked fuel line from pump but hadnt checked injectors. No fi codes so what could be goin on now?
gjp03954rr 07-04-2018 1:16 AM
I cant find anything in the shop manual about the injectors not working without a code. After checking grounds and wiring harness connectors whats left? Anyone with an idea?
machinehead 07-11-2018 4:47 PM
perhaps they are simply gummed up from old/bad fuel so the ECU fires them, there is an electrical circuit, so the ECU does not throw a fault, but at the same time you've no fuel becasue they simply wont open!
gjp03954rr 07-15-2018 10:22 PM
I will clean them but didnt seem like they would all not spray anything at all at the same time and it has only had 100% pure gas with no ethanol since ive had it
gjp03954rr 07-29-2018 11:33 PM
It wasnt the injectors wasnt working, it was that they werent getting fuel. After changing fuel pump i put fuel lines on backwards even after going by shop manual
BigdaddyPaz 07-29-2018 11:40 PM
were you able to put the fuel lines back the way they supposed to?
gjp03954rr 08-01-2018 12:14 AM
Yeah got them put back right. I put an aftermarket adjustable fpr on it now it runs like a charm. Just have a few more bugs to fix like a broken bolt on fuel pump causing a slow drip. Bolt was broken when i got it. I put sealant on gasket and it stopped leak for a while but now its started back.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
