-   -   954 engine knock (https://www.fireblades.org/forums/honda-fireblade/31113-954-engine-knock.html)
sullijs 11-05-2004 2:41 PM
954 engine knock
I have an '03 954 with about 18,000 km's. Always over maintained and pampered, but ridden moderately hard. 99% sport riding/touring, a couple of track days. Frequent oil changes. Last year detected some infrequent knocking from the engine, usually at idle, going away with increased rpm. This year, knocking is more frequent and only occasionally do I not hear it. Has anyone else on the forum experienced this? I've spoken with another 954 owner who has the same problem. Honda says "we haven't heard anything like this". Any help appreciated.
nedro 11-05-2004 3:48 PM
Re: 954 engine knock
Sounds like your oil pump is giving out.
CBR929RE 11-05-2004 4:07 PM
take a long screwdriver or pry bar, put the handle against your ear and the other end on different parts of the engine and see if you can hear where the noise is coming from. once you locate the general place in the engine where the noise is you have it narrowed down to whatever is in that part of the engine. Learned this trick from a friend's father who is a mechanic, we all call him The Legend because as he says "if it has an engine I can fix it"
ConqSoft 11-05-2004 4:08 PM
Or buy a stethoscope.
CBR929RE 11-05-2004 4:17 PM
yeah but then you might slip and burn your hand. how high a temp can a stethoscope handle? the screwdriver/pry bar way doesn't involve buying anything since you probably already have one. the longer the better so you can get your head away from the total noise of the engine.
2OHOH2 11-05-2004 4:40 PM
http://www.fcsurplus.ca/shopping/shopexd.asp?id=1485
CBR929RE 11-05-2004 4:43 PM
Originally Posted by 2OHOH2
you know what :twofing: you still gotta go buy that.
that thing looks like it'd be a good investment for a mechanic though.
Sugoi8 11-05-2004 5:11 PM
There have been cases of "knocking" due to piston scuffing. The pistons in the 954 (as in other brands/models) have little or no "skirt". Essentially you have the piston top and just the bosses that hold the wrist pin. The crown of the piston is approximately 5/8" or 16mm thick. In addition the "skirts" have a moly coating. The only fix is replace the top cylinder and pistons/rings.
If your bike is still under warranty, Honda "should" repair it. But to get Honda to warranty the problem, you have to have your dealer tear the motor apart to see if this is the problem.
Sugoi8
nedro 11-05-2004 5:39 PM
Sugoi8
Then why would the noise go away when the RPMs go up?
Conq: Good one! Just make sure that when using the mechanics Stethoscope, DO NOT SMACK IT AGAINST ANYTHING HARD!
Don't ask me how I know this.
Intimidator 11-05-2004 7:59 PM
I think I may know what you're talking about. I'll hear a knocking sort of noise coming from the engine for about the first 8 seconds after startup when it's been sitting overnight. Otherwise, it makes no noise. When it does it, it seems like more of an intermittent sound, unlike a typical old chevy engine cold startup knock. My buddy has an 03 954RR that does the exact same thing. The other day I changed the oil and it did it waaay worse for about the first 5 startups. No idea why though. :idunno:
rogerjt 11-26-2004 9:42 PM
i just bought a 2003 954 and the bike makes the same noise when it is cold and evrery couple of minuites after but no noises when i give it throttle i only have 1200 miles i'm going to get it checked out and i'll let you know :confused:
CBR929RE 11-26-2004 11:04 PM
try my long screwdriver tip, it worked for him.
jafo 11-26-2004 11:59 PM
Try decarbing with some seafoam or gm top end cleaner,seems to help a lot of engines that have piston slap/knocking in the a.m.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
