hi i have a 02 954rr and i removed the passenger pegs and the bolts from pegs are the same for spools so if your not running rear pegs use the bolts from there into your swingarm, it screws all the way in yet leaving you room for your spool stand. thought i would share why waste $10-$20 if you can have them free. sorry if its a stupid or obvious post. i dont know if its the same with every honda but it dosent hurt to try.......
The bolts holding pegs are the same with bolts for spools on 954?!? I think I got you wrong. They are not MY 954.
Althou what do I know. I better go check.
Now you realy got me thinking... Isn't there at least 2mm difference??
yup, the 2 bolts that hold the passenger pegs screw right in the swingarm where your spools are suppose to screw. it screws 90% in youll know when it max out(hand tight them), then do not over tight just 1/4inch. sorry if im confusing you or anybody.
