1 - 20 of 20 Posts
I put my 929 into storage almost 4 years ago when i PCS'ed to Japan. I am getting ready to head back to the states and am eager to get it back up to scratch.
I'm wondering what I will have to do other than the obvious things like an oil change and new battery and perhaps coolant change. Will the tires still be any good? they where less than a year old bt016's.
I want to start doing some track days soon after returning as well but need to make sure the bike survived hybrination. I was only able to siphen the tank out and disconnect the battery before storage. will I run into any problems like my power commander losing its map or anything due to it being unpowered for so long?
Ive really been missing my blade bad over here and can't wait to ride again soon.
please dont siphen your tank next time. that is what makes them rust. so check for rust in the tank. you will probably be safe since it was only 4 years. its best to fill them all the way up and and stabilizer.
if your going to do track days.... id replace those tires. gotta be safe. your PC should be fine once you put the new battery in. id flush that brake fluid. and just an over all safety inspection. you wouldnt want to go hard on it and find out a caliper has seized up due to sitting or something like that....
welcome back!
i had no choise with the tank because the storage company required it.
hopefully i can do most the work myself
awe... ok. well im sure it will be fine. just see if you can visually inspect the tank with a flashlight or something.... all the other stuff you should be able to do. bleeding the brakes is easier with a buddy who can help... but oil and filter is simple. best of luck! let us know how it goes!!!
Remove plugs and a few drops of oil down the bores, hand turn it over, to get oil moved around, and rings lubed
how do you hand turnover the motor? will hand turnover be enough to get oil pumping or should I crank it over with the ignition disabled for 20 seconds or so. also whats the point of putting oil down the bores. all a few drops will do is oil one little spot on the rings wont it?
Thanks for the tips. I really want to get it up and going the right way after such a long sleep. I did start it up and ride it a short distance just over 2 years ago when I went home to collect my family. it will be September when I pull it out of storage.
It has been in my mind a lot more lately since i learned I am PCSing back to the states. Been looking up twisties near possible assignments and really itching to get back in the saddle. I could have brought it to japan with me but the riding season up north is very short and didn't want it to be out in the elements so much.
What about the injectors and fuel system. will a couple tanks with injector cleaner do the trick or will I have to get more serious with it. I think I added some fuel stabiliser to it before they came to pick it up but they made me drain as much fuel out of it as i could. At least it was stored out of the elements somewhat in a crate inside a warehouse. how much damage could 2 and a half years do under those conditions?
this is the plan
inspect the fuel tank for rust
replace the coolant with water and water wetter (track prep as well)
replace oil
fresh fuel with injector cleaner
new oil filter
new fuel filter
new battery
new brake fluid
new tires
new brake pads (dependant on wear)
oil down the spark plug holes and let soak overnight
put it into gear and roll it a bit to get the pistons moving then crank it over with the ignition off to get the oil to circulate before starting it up.
is all that neccisary if thre is no corrosion apperant on the bike or in the fuel tank?
Discussion Starter #8 (Edited)
how can I disable the ignition to crank the bike without it starting on the 929? and is pulling the spark plugs a pain or can it be done in a few minutes?
Shame you didn't because I loved riding the roads near Misawa when I was stationed there.
Spark plugs: Have to prop the tank up and take airbox out. It takes a bit of time the first few times you do it. Id say 20 - 25 mins or so all together if you are slow and methodical about it..
Got my bike back yesterday!
I checked the fuel tank and its as good as new thank goodness. The bike is still spotless and it was stored with care. I had drained some of the oil out of it before storage so I put a couple quarts of fresh oil in and along with a new battery and fresh fuel with injector cleaner in it and took it for a short spin to get it warmed up. Then I drained the oil and changed it out with Repsol 10w40 and put a new filter on it. the tires still look to be in top shape but I have some Q3's on order for the track day. Going to just take it easy at the track to get used to the bike again. next I am going to pull the upper fairings off and clean everything and replace the coolant with distilled water and water wetter. I've also got new front brake pads and SS front lines coming along with all my new track gear. Going to take it to big willow next month. need to try and safety wire some of the bits but need my drill first to get some attach points but it and most my tools are still being shipped
Discussion Starter #14
tires look to be in tip top shape. Still I will replace them before my first track day next month for the piece of mind. I don't want the question of 4 year old tires to be haunting me while I'm trying to hustle around the fastest road in the west.
:clap::clap::clap::thumb::thumb::thumb:
Discussion Starter #16
with the fairings off I can't stop spot cleaning. the bike wasn't even dirty to begin with but I keep finding little corners with grime and want it spotless. I did promise my 12 year old a ride to school tomorrow however so I guess I need to put my obsessive spot cleaning to rest and panel this thing back up
Yeah, I know the feeling. My obsessiveness drove me rebuild a perfectly good running engine. :rotfl: And before every ride even though there is not a spec of dirt on her she gets a quick polish with the spray wax:D
Discussion Starter #20
All put back together now. Ready to ride it to work tomorrow for my first day. Just have to wipe it down with some quick detail spray and ill be ready to ride
1 - 20 of 20 Posts
