1 - 12 of 12 Posts
the 929 cranks but won’t start. It started out as no fuel from the injectors but fuel pump primed and had spark. now the fuel pump wont prime, no spark and the fi light is on solid. no voltage to fuel cut relay the engine stop relay clicks on and bas works. have my 9 volts going into the ecm, the stop switch works as it should. i really hope its not the ecu. are there things to check still that im missing???
Are all fuses OK including 20Amp Fi fuse, have you tried swapping the Headlight Relay with the Fuel Cut Relay,, Check continuity at the ECM Earth wire.
Discussion Starter · #9 ·
I’ve done those checks on the cam and crank pulser. The crank puts out right around 1.3v and the cam puts out like .2v .3v. It might be because I’m not using the right type of meter. Are the black wires to the coils supposed to have 12v?
1 - 12 of 12 Posts
