need help! my 2001 f4i 600 will start up but dies if any throttle is given. The bike has fresh oil change, new air filter, plugs, battery, fuel pump and cpu. not sure what els to try please help.
when you say that the bike stalls when you get on the throttle, does it die as soon as you twist or does it rev up a little b4 stalling??
This might be a problem, but the bike does not like to cold start. If i spray starting fluid into the throttle bodies it starts right up and will rev up just like it should. Its like its not getting enough fuel.
changes some parts still wont run almost everything has been changed and i am out of ideas. need help
