have a 2002 954 that will crank but not start. Problem started out as the bike WOULD crank….then die off like battery not getting juice.
Tested battery and is OK. Since then I have replaced: the stator, regulator, starting motor, and spark plugs.
Currently the bike just turns over and will not start. It doesn’t go dead anymore, just cranks. Fuel pump is priming and sounds like it always has.
Any input or help is appreciated on what to try next. FPR? Side stand switch?
Thank you!
Heeza Y Zasch
I'd check for proper valve seat & clearance...
...that is, if the above stated is within spec :deal:
You replaced the plugs, but did you check that you were getting a spark? Are you getting fuel, e.g. do plugs get wet?
